door locks? who used what?
Postby fishfreek » Wed Feb 20, 2013 5:20 am
I am the stage of my build where I am hanging my door. I am looking for lock /handle suggestions. I have 3/4" thick walls on my camper and don't find much made to fit this size except screen and storm door hardware.
Thanks
Fishfreek....
fishfreek
Re: door locks? who used what?
Postby wyldesyde007 » Wed Feb 20, 2013 7:10 am
http://www.worktruck-outfitters.com/hardware-work-trucks-door-handles-door-locks-c-21_148.html
I have used paddle handles in 3/4" material although you may find that you have to put a backer plate behind the latch though because the mortise for the lock will usually cut almost all the way through your 3/4" material.
wyldesyde007
Images: 131
Postby pohukai » Wed Feb 20, 2013 9:42 am
I used regular door handles from Home Depot (I think $8.00 each)
pohukai
Images: 9
Postby NathanL » Wed Feb 20, 2013 10:05 am
RV trailer lock. I believe they adjust down to 3/4" up to 1-1/4" but you'll have to check. If they don't you can always add a spacer on the inside just larger than the lock.
NathanL
Postby bobhenry » Wed Feb 20, 2013 10:40 am
You have to look thru to see the national hardware slide lock on the far door.
These are great for simple surface mounting and they have a turn knob to assure the slide is not slipped open by accident if you choose to engage it.
Postby S. Heisley » Wed Feb 20, 2013 6:42 pm
I used a security screen door latch and dead bolt set, coupled with a mending plate for the dead bolt to latch onto.
Postby suckerpunched » Wed Feb 20, 2013 8:07 pm
Mine are lockable from the outside....inside I use simple hook and loop screen door kinda things...and a 357 magnum....for bears and stuff.
If you see my harley on a trailer,,,,call the police cause it's being stolen...
suckerpunched
Images: 22
Postby KCStudly » Wed Feb 20, 2013 9:41 pm
suckerpunched wrote:and a 357 magnum....for bears and stuff
+1 on the .357 mag. :thumbsup:
Postby grant whipp » Wed Feb 20, 2013 9:43 pm
Depends on how fancy/elaborate or how basic/KISS you want to make it. For traditionality and reliable simplicity with both outside and inside security, it's hard to beat the simple outside locking L-Handle with lockable inside door latch: http://www.lilbear.teardrops.net/parts2 ... oorhandles
However you choose, Good Luck, and as always ...
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
