So I will hopefully get cutting out my side profiles this weekend. If you look at my build thread you will see I am going with the "Simple" profile as from the design library and a plain rectangle door.
I am using 3/4" plywood for my sides. Anyone see any problem with clamping both pieces together and making the cuts just once?
I know the generic plans warn against this but from what I understand that is because of the curves and need to use a jigsaw. I will be using a circular saw and have all straight cuts.
