Ranger Rod wrote:While we're having this plywood discussion, has anyone tried using MDO (Medium Density Overlay) it is used for signs, etc. and is resin impregnated to stand up to exterior use. I have been thinking of using it on my trailer since I'll be using epoxy paint. I don't want to worry about checking as you have to with fir ply (even marine grade)
Chuck Craven wrote:Ranger Rod wrote:While we're having this plywood discussion, has anyone tried using MDO (Medium Density Overlay) it is used for signs, etc. and is resin impregnated to stand up to exterior use. I have been thinking of using it on my trailer since I'll be using epoxy paint. I don't want to worry about checking as you have to with fir ply (even marine grade)
My experience with MDO is it is 1: it’s heavy, 2: does not hold up to vibration very good.
It works for small sings but for lager signs it has to be edge and cross braced.
Chuck
norm perkiss wrote:(snip), apply some quality caulking to the edges before you paint or install. Run a bead and force it in to the fibers and any voids along the edges. (snip)
Norm
norm perkiss wrote:I've done some sign work using MDO. It is very stable. To help weather proof the MDO or any plywood, apply some quality caulking to the edges before you paint or install. Run a bead and force it in to the fibers and any voids along the edges. I use my fingers to smooth the caulking. Can you say splinter...
Norm
Chuck Craven wrote:
Norm is right I was thinking of MDF fiber board with a water resistant glue.
Comes in 3/4" and is very heavy.
