ACX vs. CDX?
ACX vs. CDX?
Postby fornesto » Mon Jan 03, 2005 4:27 pm
I would like to be able to use CDX on my tear due to the cost and availablity. Most instructions say ACX, but that's double the price. I will be skinning in aluminum and want it to stick. I've heard that the aluminum is actualy held in place by the trim anyway.
Is there any problem using CDX instead of ACX?
fornesto
Postby Steve Frederick » Mon Jan 03, 2005 8:03 pm
Cdx is, at least where I live, very rough stuff to work with in a project like a Teardrop Trailer. It's hard to get/keep straight. It has voids, and is usually only three ply...the reason it's hard to keep flat. Acx is flatter, has any voids filled, and is more plys. I used cdx when I built my house. I used it in the roof. I recently built my garage/shop. I used waferboard everywhere. It's more stable and is flat when you lay it out. For a Teardrop, it would be way too heavy.
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby Ron Dickey » Tue Jan 04, 2005 12:44 pm
Cdx Acx ??
is this a glue or a siding (feel like I am eves dropping)
Time like this make me wish we had a glossery
Any one have a glossery of terms on their site?
Ron D.
173882......173887
Ron Dickey
Images: 787
Postby SteveH » Tue Jan 04, 2005 1:44 pm
The first two letters are the grade or quality of finish. A being the best, on down to D being the worst on each side, I think. So, AB would be a very finished grade of plywood. I believe the X is weather resistant glue, but not shure, so someone else with more knowledge will have to chime in here.
SteveH
SteveH
Images: 42
Postby mikeschn » Tue Jan 04, 2005 1:46 pm
Here's some information on Plywood...
Veneer Grades
Veneer is made by placing a cut log on a giant lathe and then rotating it against a cutter. As the log rotates, the cutter peels off a thin, continuous strip of wood that is then cut into pieces, graded, dried, and eventually made up into plywood sheets.
The veneers are given a grade based on the allowable number of defects and repairs and range from A (best) to D (worst). Under the rules of the American Plywood Association (APA), here is an abbreviated look at what is permitted under each grade:
A: No more than 18 neatly made repairs are permitted, parallel with the grain.
B: Repairs and tight knots up to 1-inch in size are permitted across the grain. Some minor splits are permitted.
C: Tight knots up to 1 ½-inch in size and knotholes up to 1-inch across the grain are permitted. Limited splits are permitted, as well as sanding defects that do not impair strength. Stitching (a type of rough veneer repair) is also permitted.
C-Plugged: This is an improved version of the C veneer. Splits are limited to 1/8-inch. Knotholes and other defects are limited to ¼-inch by ½-inch.
D: Allows knots and knotholes up to 2 ½-inch wide across the grain. Limited splits are allowed, as is stitching.
Exposure Ratings
Construction plywood is also rated by the APA according to one of four weather durability classifications. These include:
Exterior: These sheets have a fully waterproof glue joint and are designed for use in areas that are permanently exposed to moisture or weather. LI> Exposure 1: These also have a fully waterproof bond and are designed for use where the construction process will subject them to long periods of weather exposure before they are fully protected.
Exposure 2: This grade is intended for use in protected construction areas where they will only be exposed to moderate moisture or weather conditions.
Interior: These sheets are limited strictly to use in protected interior environments.
Understanding the Designation
A finished plywood sheet is designated by the grades of its face and back veneers respectively. For construction projects, some of the typical grade combinations include:
A-C: With an A face and a C back, this is a common plywood for use where one smooth, solid face is required, such as cabinet making, signs and some types of painted paneling applications.
C-C Plugged: This is a good plywood for use where one smooth, paintable surface is needed. Perhaps the most common construction application is roof overhangs on porches and exposed soffits.
C-D-X: A common panel for use on roof and wall sheathing where strength and moisture durability are important, but because the panel will be covered, appearance is not a big factor.
Any tried MDO?
Postby Ranger Rod » Tue Jan 04, 2005 7:25 pm
While we're having this plywood discussion, has anyone tried using MDO (Medium Density Overlay) it is used for signs, etc. and is resin impregnated to stand up to exterior use. I have been thinking of using it on my trailer since I'll be using epoxy paint. I don't want to worry about checking as you have to with fir ply (even marine grade)
Ranger Rod
Re: Any tried MDO?
Postby Chuck Craven » Wed Jan 05, 2005 12:29 am
Ranger Rod wrote:While we're having this plywood discussion, has anyone tried using MDO (Medium Density Overlay) it is used for signs, etc. and is resin impregnated to stand up to exterior use. I have been thinking of using it on my trailer since I'll be using epoxy paint. I don't want to worry about checking as you have to with fir ply (even marine grade)
My experience with MDO is it is 1: it’s heavy, 2: does not hold up to vibration very good.
It works for small sings but for lager signs it has to be edge and cross braced.
:thumbdown: Chuck[/quote]
Chuck a new td builder
Chuck Craven
Images: 62
Re: Any tried MDO?
Postby Larry Messaros » Wed Jan 05, 2005 3:09 am
:thumbdown: Chuck
Chuck, are you not thinking of MDF? :thinking:
MDO is basically a waterproof plywood with a craft paper type face that is very smooth and weathers like iron when painted. Sign makers use this for long lasting signs. If I was to use any plywood with a painted surface, it would be MDO. Using it for the sides would be ok, but trying to bend it around a curved surface would be a real challenge. I couldn't find anything thinner than 5/16".
Here's one west coast manufacturer of MDO.
Larry Messaros
:snow
Cariboo Country: If you don't like the weather, wait 5 minutes!
Larry Messaros
Postby norm perkiss » Wed Jan 05, 2005 9:54 am
I've done some sign work using MDO. It is very stable. To help weather proof the MDO or any plywood, apply some quality caulking to the edges before you paint or install. Run a bead and force it in to the fibers and any voids along the edges. I use my fingers to smooth the caulking. Can you say splinter...
Norm
norm perkiss
Images: 62
Postby Chip » Wed Jan 05, 2005 11:09 am
Let me put one more kink in the question,, In building a trailer with luan interior plywood and metal or some other outside covering, could ya use 3/4" OSB as the core material and glue and screw the coating materials to it, Is it stable enough or will the warp factor be too great for a satisfactory end result...any body tried this and how did it turn out??
If this works it sure would shave a few bucks off but if its gonna be a nightmare then I just as soon pass,,
chip
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby Ranger Rod » Wed Jan 05, 2005 4:51 pm
norm perkiss wrote:(snip), apply some quality caulking to the edges before you paint or install. Run a bead and force it in to the fibers and any voids along the edges. (snip)
Norm
I was thinking of using CPES on the edges and either 1/8 or 1/4 Luan for the roof (CPES treated) then applying epoxy paint.
I think I'd stay clear of OSB.
Rod
Ranger Rod
Postby Chuck Craven » Wed Jan 05, 2005 5:01 pm
norm perkiss wrote:I've done some sign work using MDO. It is very stable. To help weather proof the MDO or any plywood, apply some quality caulking to the edges before you paint or install. Run a bead and force it in to the fibers and any voids along the edges. I use my fingers to smooth the caulking. Can you say splinter...
Norm
Norm is right I was thinking of MDF fiber board with a water resistant glue.
Comes in 3/4" and is very heavy.
:oops:
Chuck Craven
Images: 62
Postby asianflava » Wed Jan 05, 2005 7:53 pm
:oops:
That is what makes it good for speaker enclosures.
asianflava
Postby Chuck Craven » Wed Jan 05, 2005 10:50 pm
I work on audio amplifiers that are 3 channel 60,000 watts each channel.
They don’t make speakers big enough that I can’t blow up, including the enclosure, in a micro second or less.
Our voice coils weigh 3000 lbs and the magnet 8 tons. Not meant for a teardrop sound system. :shock:
Chuck
Chuck Craven
Images: 62
Postby fornesto » Mon Jan 10, 2005 1:27 pm
I got a message from the lumber yard and he said they have my "AC". I wanted ACX for the X (exterior grade). What will be the ill effects of using AC instead of ACX?....I'm not cladding in aluminum!
fornesto
