Plasti-Cote
Plasti-Cote
Postby whiteheadfisher » Sat May 01, 2010 7:50 am
Hi everyone. I just wanted to ask if anyone has ever used Plasti-Cote Roof Coating for their build? The manufacturer claims it can put over wood(brushed on or rolled on), is very durable as a skin covering.
What do you folks think? :thinking:
whiteheadfisher
Postby TwilightLane » Sat May 01, 2010 3:37 pm
That is a really interesting idea. I searched a while but couldnt come up with any more info or even a decent pic. My google-fu let me down. I'm curious to hear what anyone has to say. Esp for applications on wood.
Rob & Lori
Aspen & Tundra
My Instructable: http://www.instructables.com/id/Teardro ... l-Trailer/
TwilightLane
Postby goldcoop » Sat May 01, 2010 3:50 pm
Sounds expensive? :o
Coop
goldcoop
Images: 32
Plasti-Cote
Postby whiteheadfisher » Sat May 01, 2010 3:53 pm
Not really. What I've seen online is only $40 a gallon. I claims to cover 200 square ft. per.
Look up Elasti-Cote also.
whiteheadfisher
Postby whiteheadfisher » Sat May 01, 2010 3:55 pm
I'm sorry, look for Elixir industries.
whiteheadfisher
Plas-T-Cote Elastomeric 100% Acrylic Roof Coating
Postby whiteheadfisher » Sat May 01, 2010 3:58 pm
Look this up.
whiteheadfisher
Postby Jason and Amanda » Sat May 01, 2010 4:07 pm
Closest I can find is http://www.plastikote.com/index.jsp
Almost exclusively automotive stuff.
Jason and Amanda
Images: 89
Postby Jason and Amanda » Sat May 01, 2010 4:10 pm
You posted after I opened the thread.
This instead? http://www.elixirind.com/
Jason and Amanda
Images: 89
Postby Jason and Amanda » Sat May 01, 2010 4:12 pm
I see they have aluminum and vinyl. I don't see anything that can be brushed or rolled on as a coating over an existing surface.
Jason and Amanda
Images: 89
Postby Jason and Amanda » Sat May 01, 2010 4:14 pm
Wait, I think I found it. It's called: "Plas-T-Cote"
Check out this link:
http://www.elixirind.com/?page=products&productid=35
Copied from the page:
Roof Coatings
Elixir Industries is committed with offering the best Roof Coating in the industry. With a variety of coating products, Elixir Roof Coatings can fill a myriad of job applications.
Alkyd Fibered Roof Coating: (not suitable for rubber roofs):
Coating for metal and fiberglass roofs. Alkyd Fibered Roof Coating is a non-asphalt, high quality chemically engineered roof coating that contains long fibers, pigments and non-drying resins. It is a thick, white fibered or aluminum fibered colored coating with an amazing ability to conform to, an protect against all weather conditions. It has excellent acoustical and insulating qualities.
Fibered Asphalt Aluminum Roof Coating (not suitable for rubber roofs):
Fibered Asphalt Aluminum coating seals and protects roofs from 80% of ultra-violet sun rays. It reduces inside room temperature up to 15%. Formulated to protect metal and aluminum roofs. One gallon covers 80-100 square feet. Meets ANSI/ASTM No. D-2820 Type II.
Plas-T-Cote Elastomeric 100% Acrylic Roof Coating:
Use over asphalt roof shingles, galvanized steel, concrete, wood, polyurethane foam, and bitumas built up roofs (BUR'S). Used as a reflective and protective coating. Has outstanding exterior durability and UV resistance. Expands and contracts with the roof. Resists cracking and withstands impact. Non-polluting and non-toxic.
Plas-T-Cote Rubber roof coating:
Use over rubber roofs, at seams and tears, and to seal vents, air conditioners, etc. Has outstanding exterior durability and high adhesion to rubber. Rubber roof coating is UV resistant, and expands and contracts with roof. Resists cracking and withstands impact. Non-polluting and non-toxic.
Plas-T-Cote patching cement:
Long lasting patching cements. Stops leaks fast. Just brush it on.
Plas-T-Cote Glass Fabric: A reinforcing membrane for use on cracks 1/4" or larger. This fabric can be used with patching cement, fibered aluminum and alkyd roof coatings.
Plas-T-Cote Patching Tapes:
Pliable butyl rubber press-on tapes for roof repairs. Stops leaks fast.
Plas-T-Cote Repair kit:
A general purpose white or black plastic cement and patching compound for patching and filling cracks and holes prior to applying other coatings.
Please contact your Elixir Sales Representative for further details.
Jason and Amanda
Images: 89
Postby whiteheadfisher » Sat May 01, 2010 4:23 pm
The 100% Acrylic Roof Coating is the product I'm referring too. I may give it try for my build.
whiteheadfisher
Postby mikeschn » Sat May 01, 2010 7:21 pm
Is it available at any big box stores?
Postby whiteheadfisher » Sat May 01, 2010 7:36 pm
The web site has a dealer locator. I haven't checked it but I plan to do so. In TN we are having some major flooding today, so we are all glued to the TV.
whiteheadfisher
Postby whiteheadfisher » Sat May 01, 2010 7:42 pm
It doesn't appear to be available at the big box stores. It seems to be an RV product. It does look like it is available online.
whiteheadfisher
Postby Grid Runner Adventures » Sat May 01, 2010 11:02 pm
I actually have a sponsorship request out with this company for that very same product to use for my off grid camper that im debuting at the June 18th wisconsin renewable energies fair.
hope they take up the sponsorship it looks like a great product.
www.offgridrving.com
Follow my build of a off grid camper that is 6x8 and I will live in it for an entire year!
Google Is My College
