Look, Ma--No Hand(le)s!!!
Postby IraRat » Tue Sep 06, 2005 8:47 am
On Sunday, I gave birth to a beautiful 20-pound bouncing baby door:
I am so proud, I hope you'll excuse me while I pause to wipe a tear from my eye. (Took me about a day and a half, because of rain delays.)
It was a happy, bittersweet, at times confusing, life experience...but one that will hopefully better prepare me for the challenges of doing the more often-used driver's side door.
My story is a unique one, and I didn't curse more than 3 or 4 times during the entire birth.
First, as you can see, I abandoned all conventional wisdom and advice and used Tee-Hinges. And as you can ALSO see, this really works with my theme. (It was pretty inexpensive too.)
As you know, even if I measure five times, that doesn't mean I'm going to do the CUT right the ONE time I have to actually do it. So I said the hell with it. I cut the ply to a very tight fit for the opening, almost no conventionally measured gaps all around. I then framed the ply with 1 X 2 pine all around, except for the curve on top, where I used ply. I glued the exterior skin on (plus some brads) and just bradded the interior. With only the sticks to adhere it to on the inside anyway, and no major water considerations to take into account, I figured brads were enough.
I lift the door to the opening, set it on top of VERY thin shims on the sill, and attach the hinges.
I set the hinges forward a little, to the right, so the door can't swing into the cabin at all. Yes, I used a "stop plate" at the bottom of the body, on the inside of the sill, but this is more for waterproofing than it's needed to stop the door.
I now try to close the door, which it is not very willing to do. But I calmly, methodically, strategically and slowly rasped down and used the sheet sander on both the door and opening edges, to achieve the desired end.
I even put my beer down a few times, because it was hard to work the rasp with one hand. (Besides, there was only an ounce or two left, and it was getting warm.)
Anyway, lo and behold, the door closes perfectly--almost. The very upper left corner sticks out a little, but the slighest pressure of even just one finger makes it flush again. So in the above photo, you may see a nail that I temporarily impacted (like that word?) into the body, and then bent over the door to make it sit perfectly flush.
My logic was that this may be a warpage issue--the body, door, or both, who knows--and maybe by letting it sit like this, it'll warp back.
Regardless, I'm not too concerned about this right now. I had been considering using large black slide bolts as my locks ANYWAY, as opposed to a lock on a standard door handle, because again, I'm going for a certain look. The bolt up top will make it sit flush. We'll see.
I then trimmed the outside edges of the door in my own unique...I hope it's kind of waterproof...style. I want to put a narrrow canopy above the door, but I haven't figured out how to adequately do the top edge of the door yet. It may be a piece of curved lumber cut to that curved top profile, that sits flush with the body when closed.
In conclusion, this was not a horrible experience at all. Perfect? No, but I DO have a door, and one-half a window. (I have some finishing work to do on that window, in the interior, and also to correctly mount it so it's really waterproof.)
Lessons learned?
Well, next time, I MAY cut the door a bit narrower than I did this time. After this one was installed, I installed a piece of self-stick foam weatherstripping on the hinge side, on the jam (not the door). After doing so, the door wouldn't close, so I had to remove it. I'm making a guess that I'm still okay, though, because there's hardly ANY gap on that side when the door is closed. Plus, with my exterior rubber trim there, it makes a really tight seal.
Who knows. Once both doors are on, I'm going to give it a hose test.
The other lesson I learned was to keep more beer in the cooler, on ice, and not just in the refrigerator.
--Ira
IraRat
Forum Storyteller
Postby Rob » Tue Sep 06, 2005 9:46 am
Ira--
That looks SHARP! 8)
Rob
:wine:
:peace:
Rob
Images: 58
Postby toypusher » Tue Sep 06, 2005 10:45 am
Congratulations! Only one more! Looks Great!
Kerry
toypusher
Images: 324
Postby IraRat » Tue Sep 06, 2005 10:48 am
Thanks, guys, I'll be mailing out cigars shortly.
--Ira
IraRat
Forum Storyteller
Postby BILLYL » Tue Sep 06, 2005 11:00 am
Ira-
You be the man!!!!!!!!!!!!!! This is great work - don't forget the rain gutter..........
Keep it up......
BILL
"If your children ever find out how lame you really are, they'll
gonna murder you in your sleep...." Frank Zappa
BILLYL
Postby SmokeyBob » Tue Sep 06, 2005 11:00 am
Nice looking door. I like the looks of the round window. :thumbsup:
Pics for Building the Alegria I
To view video click Here
Bob & Judith
SmokeyBob
Images: 161
Postby BILLYL » Tue Sep 06, 2005 11:01 am
Ira-
Keep it up......
BILL
BILLYL
Postby IraRat » Tue Sep 06, 2005 11:15 am
Oh...so it's called a RAIN GUTTER!
What the heck is that and where can I buy it in brass?
Also, I'm trying to think of a creative idea for making the narrow canopy above the door, to mount onto the body. I know you can buy premade ones for vans, etc., for square edges, but for a curve like that?
I was thinking about, maybe, buying a bunch of itty bitty shelf-type brackets, mounting them up and down to follow the curve, and then connecting some kind of material onto THAT.
By the way--I took this picture before I fixed something, and looking at this picture now , it's driving me nuts:
On the very bottom right edge of the door, there's like a 2-inch piece of weather-stripping missing that I installed after I took the photo.
Right now, this assymetry is upsetting me.
--Ira
IraRat
Forum Storyteller
Postby s4son » Tue Sep 06, 2005 11:47 am
Ira,
You obviously don't have the proper tools. Not only does this device protect your head when Mrs. Ira starts swinging, it also allows you to work almost non-stop, without setting your beer down. Best of all, you're always satisfied with the way your project turns out!
Scott F. :lol:
Are we there yet?
s4son
Images: 180
Postby IraRat » Tue Sep 06, 2005 11:48 am
Yeah, Scott--but that only holds two cans!
--Ira
IraRat
Forum Storyteller
Postby s4son » Tue Sep 06, 2005 11:54 am
All kidding aside, your door looks great. Is that the piece you originally cut from the opening?
Scott F.
Are we there yet?
s4son
Images: 180
Postby TomS » Tue Sep 06, 2005 12:58 pm
:thumbsup: Lookin good there Ira. You've overtaken me.
I just got my door hardware and my windows are coming in later this week. Maybe I should pick up a couple of cases of Bud to speed my project along.
Tom Swenson
[email protected]
TomS
Postby IraRat » Tue Sep 06, 2005 1:28 pm
s4son wrote:All kidding aside, your door looks great. Is that the piece you originally cut from the opening?
Scott F.
Thanks for the encourgement, and yeah:
All of the pieces for both sides are the original cut-out pieces, ply wall and both skins. That's why the lines of that exterior skin actually match up more or less, as well as for that same skin on the interior.
And Tom--you'll notice that I didn't post any photos of my CABIN, so I really doubt I overtook you at all. Remember my motto: Style over substance.
So I don't care if those doors ever open at ALL. As long as it looks NICE from the outside. And the wheels don't fall off.
But you'd better get some Sam Adams, not Bud--which can be POISON to a New England boy like yourself.
Us Brooklyn guys have no taste nor class, so we've built up an immunity to Budweiser and Ed McMahon.
--Ira
IraRat
Forum Storyteller
Re: Look, Ma--No Hand(le)s!!!
Postby angib » Tue Sep 06, 2005 2:40 pm
IraRat wrote:I even put my beer down a few times, because it was hard to work the rasp with one hand. (Besides, there was only an ounce or two left, and it was getting warm.)
I will be printing up that quote so I can hang it up in my workshop as a constant reminder of how the real professional approaches his work and the level of comittment needed to get the great results shown in the photo.
Andrew ;)
angib
5000 Club
5000 Club
Images: 231
Postby bennelson » Tue Sep 06, 2005 3:11 pm
Yar Matey!
Nice porthole...
still no idea what i'm doing...
bennelson
Images: 53
