Any ideas? What about getting 1 1/2" and slicing it in half (thickness -- from 1 1/2" to two sheets of 3/4")? Any ideas on how to do this?
I live in the Boise, Idaho area.
Thanks again!
John
mahai217 wrote:So, I decided to build my TD with 1/4" skin, 3/4" skeleton and insulation, and 1/8" or 1/4" interior skin. I purchased Steve Frederick's Shop Manual and working through it and have even bought some of the lumber. I've tried sourcing the insulation but can not find any within 100 miles -- maybe more.
Thanks again!
John
lrrowe wrote:This may be a silly question, but what about building with the 1 1/2 insulation. Thicker walls would mean better insulation and noise damping.
martymcfly wrote:BMC has it. I paid for it there on Franklin and picked it up out by Broadway. It was $23 a 4x8 sheet r-tech with foil on both sides.
pchast wrote:John,
Have yo looked at foamys at all...![]()
If you glue that 1.5 in. foam to the skins you will
only need some blocks to screw things too in the foam.
The skeleton would be unnecessary.
elcam84 wrote:Well dont forget how sailboats are made. They are just foam with fiberglass on both sides... Why not do the same with a teardrop and eliminate the frame and use plywood instead of fiberglass. Even something like a heavy laminate on one side would add allot of strength but everything has to be glued well.
Sent from my SM-T320 using Tapatalk
