3/4" Insulation Unavailable - What Now?
Postby mahai217 » Mon Jun 12, 2017 5:12 pm
So, I decided to build my TD with 1/4" skin, 3/4" skeleton and insulation, and 1/8" or 1/4" interior skin. I purchased Steve Frederick's Shop Manual and working through it and have even bought some of the lumber. I've tried sourcing the insulation but can not find any within 100 miles -- maybe more.
Any ideas? What about getting 1 1/2" and slicing it in half (thickness -- from 1 1/2" to two sheets of 3/4")? Any ideas on how to do this?
I live in the Boise, Idaho area.
Thanks again!
John
:NC
mahai217
Re: 3/4" Insulation Unavailable - What Now?
Postby lrrowe » Mon Jun 12, 2017 5:49 pm
This may be a silly question, but what about building with the 1 1/2 insulation. Thicker walls would mean better insulation and noise damping.
Bob
lrrowe
Images: 439
Postby tony.latham » Mon Jun 12, 2017 5:59 pm
mahai217 wrote:So, I decided to build my TD with 1/4" skin, 3/4" skeleton and insulation, and 1/8" or 1/4" interior skin. I purchased Steve Frederick's Shop Manual and working through it and have even bought some of the lumber. I've tried sourcing the insulation but can not find any within 100 miles -- maybe more.
Thanks again!
John
:NC
Arghhhhhhhh....
Iv'e been there a couple of times. On my first search for 3/4" foamboard, there wasn't any here in Salmon and nothing in the Bitterroot Valley. We had a trip planned to Spokane and I found the 3/4" pink stuff in a Home Depot. On my third 'drop, I found it in a Home Depot in Missoula––they had it in beadboard with a foam backing.
Which leads me to the second teardrop I built, a little 4 x 8 for my sister. The skeleton was made from 1/2" AC plywood. Finding 1/2" pink board was easy.
Soooo... you might consider going that route.
A skeleton made from 1/2" AC (I'd avoid the void-rich CDX) is fine for the skeleton wall with 1/4" sheathing. The other thought is purchasing 1" pinkboard and taking it down a quarter with a random orbital and 80 grit sandpaper after it's glued into your wall's holes. It won't take long. Just keep your vacuum nearby. 3/4" pinkboard is thicker than 3/4" plywood so you have to take this step anyway....
The only problem I had with my sis's walls were that the shelf the ceiling fits on is narrow. With a 3/4" skeleton, I can snap it down with my 1/4" crown stapler over a bead of glue. I was afraid to do that with the 1/2" skeleton––afraid it would split out. I ended up laying a bead of PL Premium down and nailing it down with skinny little nails. Works fine.
Postby greygoos » Mon Jun 12, 2017 6:23 pm
They sell 3/4 polystyrene insulation at Home Depot on Federal Way. They are 18 inches wide and 4 feet long. 6 to a pack. Somewhere around 10.00
greygoos
Postby Redneck Packrat » Mon Jun 12, 2017 6:36 pm
3/4 is pretty common here, all the mom&pop type places stock that but not the thicker stuff. I'm building with 2" and am having the same problem finding enough of it in decent enough condition to use.
Bill
Texas Gulf coast, near Corpus
Working on this, started 5/2017: http://www.tnttt.com/viewtopic.php?t=68614
Some days you're the bug, some days you're the windshield :?
Redneck Packrat
Postby martymcfly » Mon Jun 12, 2017 7:23 pm
BMC has it. I paid for it there on Franklin and picked it up out by Broadway. It was $23 a 4x8 sheet r-tech with foil on both sides.
martymcfly
Postby Kevin A » Mon Jun 12, 2017 9:24 pm
If all else fails, use 1/2" foam with a 1/4" or 6mm ply to fill the void.
Kevin A
The other guy
Images: 289
Postby mahai217 » Tue Jun 13, 2017 8:32 am
lrrowe wrote:This may be a silly question, but what about building with the 1 1/2 insulation. Thicker walls would mean better insulation and noise damping.
Not a silly question. I'm just planning to build so I fill the voids of the skeleton with insulation. If I used 1 1/2" insulation I would have to use 1 1/2" skeleton.
mahai217
Postby mahai217 » Tue Jun 13, 2017 8:33 am
martymcfly wrote:BMC has it. I paid for it there on Franklin and picked it up out by Broadway. It was $23 a 4x8 sheet r-tech with foil on both sides.
Thanks Marty! I will stop by!
mahai217
Postby mahai217 » Tue Jun 13, 2017 8:35 am
Thanks for all of the ideas folks! You gave me a few things to think about. I appreciate you taking the time to share your knowledge and experience.
John
mahai217
Postby elcam84 » Tue Jun 13, 2017 5:30 pm
Wow 3/4 is all the borgs here carry. Sometimes they have 1" but anything thicker is special order and very expensive. Unfortunately no Menards here.
Sent from my SM-T320 using Tapatalk
elcam84
Postby pchast » Tue Jun 13, 2017 8:19 pm
John,
Have yo looked at foamys at all... :thinking:
If you glue that 1.5 in. foam to the skins you will
only need some blocks to screw things too in the foam.
The skeleton would be unnecessary.
pchast
Images: 97
Postby mahai217 » Wed Jun 14, 2017 8:41 am
pchast wrote:John,
:thumbsup: :thinking:
mahai217
Postby elcam84 » Wed Jun 14, 2017 8:45 am
Well dont forget how sailboats are made. They are just foam with fiberglass on both sides... Why not do the same with a teardrop and eliminate the frame and use plywood instead of fiberglass. Even something like a heavy laminate on one side would add allot of strength but everything has to be glued well.
elcam84
Postby QueticoBill » Wed Jun 14, 2017 2:55 pm
elcam84 wrote:Well dont forget how sailboats are made. They are just foam with fiberglass on both sides... Why not do the same with a teardrop and eliminate the frame and use plywood instead of fiberglass. Even something like a heavy laminate on one side would add allot of strength but everything has to be glued well.
True. And why not just use fibreglass? It does depend on the adhesive.
QB
QueticoBill
Images: 22
Users browsing this forum: Bing [Bot] and 5 guests
