Plastic hatch hinge questions
Re: Plastic hatch hinge questions
Postby steve cowan » Tue Jan 30, 2024 12:20 pm
Used the plastic hinge from Vintage Tech.Put aluminum 1/8" x 1" flat stock on top of hinge with screws about 2- 1/2 inches apart across to keep hinge flat.This worked good and never leaked.
steve cowan
Images: 207
Postby italianub » Tue Jan 30, 2024 12:58 pm
I think the plastic ones you guys are using are very different than the centaflex one - The "plastic piano hinge" one from vintage technologies doesn't look great to me since it's got that tiny strip of plastic that is the hinging point. This centaflex hinge looks like this:
The hinging part seems thicker, and the overall construction of this seems much more rigid. I reached out to the guy on the channel that I found this on and he said after 3 years it's still holding up with zero issues. I will, however, try and build the door to be a bit lighter than my original plan, and make sure the gas struts are holding a lot of the weight, even in closed position. I would much rather have to replace a strut than the hinge, despite the cost. If this lasts for a LONG time and can keep the water out, I'd call it a win for sure.
I'm still drawing out my galley hatch (squaredrop, not curved) and will be posting it as soon as I finish so you guys can give your thoughts on it :)
Build began Feb 10th, 2024
Build journal: viewtopic.php?f=50&t=76227
Video build journal: https://www.youtube.com/playlist?list=P ... 0ZP7TwtcT3
italianub
Postby tony.latham » Tue Jan 30, 2024 1:22 pm
I'm still drawing out my galley hatch...
I hope it works and I'll be anxious to see your hatch.
Postby WhitneyK » Tue Jan 30, 2024 1:38 pm
italianub wrote:I think the plastic ones you guys are using are very different than the centaflex one - The "plastic piano hinge" one from vintage technologies doesn't look great to me since it's got that tiny strip of plastic that is the hinging point. This centaflex hinge looks like this:
That does appear to be a much better design than the one I used.
Whitney & Tracie
Crothersville, IN
We never really grow up, we only learn how to act in public.
Do not confuse what you hear with what I mean.
My build: http://www.tnttt.com/viewtopic.php?t=41955
160061-------------------------------101114
States we've drug our
li'l camper through. (44 States + Vancouver Island and over 45,000 miles so far)
WhitneyK
Images: 412
