But youve got to call Ol Chip and order some of his Famous Pickle Juice...
He,ll most likely be happy to advise you on how much you,ll need for the duration of the project....
It,ll be nice to follow your progress..
Classic Finn
Ira wrote:You just used 1 by 2's for that framing?
I don't know...
3/4" high doesn't give you much to screw into--especially for those sidewalls. Even the very minimalist Cubby plans call for 2 by 2s.
I would screw/glue (laminate) additional 1 by 2s around the perimeter. You said you were worried about overbuilding it using 2 by 4s, but going from 2 by 4s to 1 by 2s is a BIG leap.
HEY, AND ALSO!!!!!!
WATCH THAT GLUE AROUND THE DOG!!! DANGEROUS STUFF!!!
elmo wrote:Ira wrote:You just used 1 by 2's for that framing?
I don't know...
HEY, AND ALSO!!!!!!
I am kind of using the Generic Benroy plans and that is what is suggested there, but does look hard to hit straight with a screw.
If it is alright for Mk it is alright for me!
Ira wrote:elmo wrote:Ira wrote:You just used 1 by 2's for that framing?
I don't know...
HEY, AND ALSO!!!!!!
You're right--her post came up while I was typing mine.
Makes sense--I just thought the Cubby plans were so minimalist that anything less than that was stretching it.
As far as putting 2 by 2s in the interior, it would be easier and cleaner to do what Jack does:
He uses simple angle aluminum (the L-shaped stuff) to tie everything together. Also, you're framing and insulating, right?
So even without it, those walls aren't going anywhere.
gyroguy wrote:I don't want to oversimplify this... but! Take a shoebox. Rip the edges off the top. Put the top, sans edges, on the floor. Turn the shoebox over. Align it on the shoebox top. It really doesn't want to fall off.
That's kind of how I look at your project. Once you attach the body to the floor, the body goes where the floor goes.
Will the body be stiff enough to not shift and tilt? Sure. That's what the cross-bracing for the shelves, the back of the galley, etc. does for you. It stiffens the box. Even the teardrop shape stiffens the box, because it makes it harder to bend.
The Crocodile Tear has lineolum over the floor. I cut it off where the sides would drop down on it. I epoxy glued it, screwed it, and added a dozen 1" x 1" x 3" long aluminum angles for the heck of it. The only other trick was slotting the quarter-round trim before I put it down where the wall joins the floor.
Main thing is, though -- it's your trailer and you can do what you want to!
