UGH - 1 Door Warped
Postby Classic Finn » Fri Feb 16, 2007 3:43 pm
halfdome, Danny wrote:Heikki, it looks like you are dealing with two differently sealed surfaces, one aluminum and the other finished wood. The moisture will be absorbed more on the wood side even though it is sealed. If it's bowed on the outside sightly (convex) the hinge and door latch just might pull it up along with weather striping. I would store them inside wrapped in a heavy blanket. Beautiful veneer,. Is that Honduran Mahogany? :D Danny
Danny you explained it lots better than I did.. yes thats the way its warped exactly... :oops: Danny here it is called Sable Mahogany... Im not sure of the real name...
Heikki
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Classic Finn » Fri Feb 16, 2007 3:46 pm
Micro469 wrote:Heikki, How bad is it warped? Maybe you can just put some 2x4's under the edges and put some heavy weight on top and let it sit a couple of days in the house. It might warp back without taking it all apart...... ;)
I was looking at it also of doing it that way....Its not soooo bad but we can tell it is....But I think I will take the moulding off and then press it..Its been in the house for about a week now or over...
I could try the 2 x 4 .....and clamps..
Heikki
Classic Finn
Images: 146
Postby Mary K » Fri Feb 16, 2007 4:07 pm
Classic Finn wrote: Ok Mk.. I,ll trade ya that there door for a nice towbox... :lol: :lol:
I will send it out tonight....:lol: :lol:
Classic Finn wrote:PS Mk this is for you... here is the other side...
Ohhh, Pretty!! I will send a engagement ring too :lol: :lol:
Ya know I would start with the easy fix first, like the 2x4's if I waz ya!!
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Classic Finn » Fri Feb 16, 2007 4:16 pm
Mk
WOW Cool a New Towbox plus an engagement ring too.... :lol: :lol: :lol: HAH!
I,ll give it a whirl..
Wonder what a low heated Sauna would do if clamped in between a couple of 2 x 4s and tightening clamps everyday till sgtraight?
But then the cooling could cause somthing else... :thinking:
Classic Finn
Classic Finn
Images: 146
Postby Mary K » Fri Feb 16, 2007 4:53 pm
Classic Finn wrote:Wonder what a low heated Sauna would do if clamped in between a couple of 2 x 4s and tightening clamps everyday till sgtraight?
Classic Finn
Hummm... :scratchthinking: That might be an idea. Can ya try it on a scrap piece of wood? Then put it in a low humidity room in the house to see what happens???
mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Classic Finn » Fri Feb 16, 2007 5:31 pm
Darn Im being dangerous and abusive to my door.... :scratchthinking: :duh
Classic Finn
Classic Finn
Images: 146
Postby rbeemer » Fri Feb 16, 2007 5:45 pm
Heikki,
I would not use the Sauna ieven if it was a dry heat becuase you want to slowly remove moister from the wood and sometimes with dry heat you can remove too much possibly causing the veneer to crack or split even if it is finished.
If it is in the house the humidity is more constant and usually not too dry.
Rick
If ducks had scales, would fish quack?
rbeemer
Postby Classic Finn » Fri Feb 16, 2007 5:51 pm
rbeemer wrote:Heikki,
Thats what my Uncle said too... So I think I,ll just take the moulding off and clamp it in between 2 boards.. in 2 different areas of the door...
As Danny also mentioned it could draw back together when put back in place... I,ll find out and let you all know... By May anyhow.. I,ll need the door on it by then for sure.. :lol: :lol: :lol:
Heikki
Classic Finn
Images: 146
Postby Jiminsav » Sat Feb 17, 2007 7:41 pm
man..ya'll just think too much..put it back outside leaning the OTHER way..and viola, bend goes away.
Jim in Savannah
Jiminsav
Images: 40
Postby Joamon » Sat Feb 17, 2007 8:15 pm
Jim I sure like your thinking cause when my door warped that is the
first thing I did (Didn't work to well but I tried).
Keith
Joamon
Images: 244
