by doug hodder » Wed Mar 14, 2007 9:25 pm
Critter....sand it all down with like an 80 grit....do 1 coat of regular epoxy...the top coat catalyst...sand...fill all the holes, divots, marks etc, with microballoons, bondo or whatever you choose...sand that part down...then a couple more coats of epoxy with sanding inbetween, use a firm rubber block and that will knock down the high spots or be real careful as using the edge of the sander you'll get some waves in it....then paint...I've never had 1 coat of epoxy cover up everything so that I could shoot paint on it...it just isn't smooth enough...all is not lost, and if you put skins on the exterior...you're going to go through the same stuff on them anyway, only they may not lay down as flat as you would like and then you have a big high spot to take care of...You can't rush that type of finish, takes time and patience, and lots of sanding...don't give up, just chalk it up to a learning lesson, you've learned lots of things that don't work, unfortunately, you can't get back the time and the dough spent on that part...Doug
