How to screw up a teardrop
Postby critter » Wed Mar 14, 2007 6:00 pm
Hey Guys.
I dont do the wild turkey thing just micky lobes but i wuz thinkin bout setin her on fire and callin my pickin buddies and havin a jam session over it.but that wont work cause my son is a fireman lol and no the camera aint broke its just that ol moneybags is the only one that can putem up onto the computer and that dang insurance co keeps her away from me all day! :cry:
critter
critter
critter
Images: 54
Postby Geron » Wed Mar 14, 2007 6:25 pm
I thought they all had dents, dingies, and other thingies in the wood. I've always called it "character" even better patina. Everybody just "loves' patina.
:lol: :lol:
g
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Postby Micro469 » Wed Mar 14, 2007 8:51 pm
THE ANSWER>>>>>Henry's carpet glue,,and....ALUMINUM..... :thumbsup:
Or cover the outside in Astroturf..... Call it the TEARDOME..... ;)
John
Micro469
Images: 382
Postby doug hodder » Wed Mar 14, 2007 9:25 pm
Critter....sand it all down with like an 80 grit....do 1 coat of regular epoxy...the top coat catalyst...sand...fill all the holes, divots, marks etc, with microballoons, bondo or whatever you choose...sand that part down...then a couple more coats of epoxy with sanding inbetween, use a firm rubber block and that will knock down the high spots or be real careful as using the edge of the sander you'll get some waves in it....then paint...I've never had 1 coat of epoxy cover up everything so that I could shoot paint on it...it just isn't smooth enough...all is not lost, and if you put skins on the exterior...you're going to go through the same stuff on them anyway, only they may not lay down as flat as you would like and then you have a big high spot to take care of...You can't rush that type of finish, takes time and patience, and lots of sanding...don't give up, just chalk it up to a learning lesson, you've learned lots of things that don't work, unfortunately, you can't get back the time and the dough spent on that part...Doug
Postby bledsoe3 » Thu Mar 15, 2007 4:00 am
Just go buy two sheets of luan and glue to the sides. Then route off the excess. You have two perfectly smooth surfaces with no holes or screws showing.
Before
After
bledsoe3
Images: 112
Postby Ira » Thu Mar 15, 2007 7:47 am
bledsoe3 wrote:Just go buy two sheets of luan and glue to the sides.
Ditto. And again.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby critter » Thu Mar 15, 2007 12:15 pm
Hey Guys,
I guess im going out to sand off all the ugly and well see what happens :roll: makin dust again!
critter
critter
critter
Images: 54
Postby critter » Thu Mar 15, 2007 1:03 pm
Oh well,
The dust turned to gooo,guess ill have to wait on the paint to dry a little longer. :?
critter
critter
critter
Images: 54
Postby critter » Thu Mar 15, 2007 1:08 pm
Hey bledsoe,
Somebodys standing in you tear!I can see their leggs :)
critter
critter
critter
Images: 54
Postby bledsoe3 » Fri Mar 16, 2007 2:06 am
critter wrote:Hey bledsoe,
Somebody's standing in you tear!I can see their leggs :)
I just went out and checked. As I walked up I could see the legs but when I opened the door there wasn't anybody in there. I have a haunted tear. :frightened:
bledsoe3
Images: 112
Postby angib » Fri Mar 16, 2007 10:07 am
bledsoe3 wrote:As I walked up I could see the legs but when I opened the door there wasn't anybody in there.
Hey, that's cool - there's a light in my refrigerator that works much the same way......
Andrew ;)
angib
5000 Club
5000 Club
Images: 231
Postby critter » Tue Mar 20, 2007 12:38 pm
Hey Guys,
This sanding thing aint going to good.sandpaper keeps clogging up with goo.Is this paint still not dry or whut?The ouside layer seems to sand ok but the inside seem to be goo.Is there any way speed this up?Tired of sitting round and watching paint dry! :cry:
critter
critter
critter
Images: 54
Postby Keith B » Tue Mar 20, 2007 1:46 pm
Depends on the paint you used and how thick you put it on... Latex? I'd say it wouldn't be dry yet. 2.) Enamel? it DEF is not dry and hard yet. 3.) 2 part-epoxy paint - I'd think it'd be dry after a week.
I think you'll find you're going to get lots of clogging at this early stage. Since you are "taking" it down, I'd go get some chemical stripper and let it do it's thing (just try not to get it on the chasis so you don't create more work) - get the BULK of it off, then sand to get it re-smoothed so you can fair and fill as you find necessary.
Keith
"Work and work and do your best! Paint and putty will do the rest!"
Keith B
Postby critter » Tue Mar 20, 2007 2:53 pm
Hey Guys,
I used this poly enamel stuff this guy at the paint store recomeded.He says its the next best thing to 2part epoxie... on top of kilz.i figure its cheap but efective.....i hope!
critter
critter
critter
Images: 54
Postby toypusher » Tue Mar 20, 2007 2:59 pm
critter wrote:Hey Guys,
Got any hologen work lights? If so, set on high and point at the are you want dry.
toypusher
Images: 324
