Keith B wrote:Shucks... well, don't thow them in the trash just yet... you might have a brain storm tonight and get 'er figured out...
elmo wrote:Keith B wrote:Shucks... well, don't thow them in the trash just yet... you might have a brain storm tonight and get 'er figured out...
Trust me I have been brainstorming...without putting on another door handle at the top.I measured and it is about a 1/4" that is screwing me up.
Eventhough everything I touched today went wrong I went back out and got all my lights up...except one...another brain storm project, but not as serious as the door. Also got the Fantastic Fan up and running.
bledsoe3 wrote:Elmo, what kind of door seal are you using? Grant's door trim is .360 and should take up that gap.
Ira wrote:Why do you think sealing is going to be a problem using the diamond plate?
Because of the raised etch marks, that the t-molding won't sit flush?
Keith B wrote:Just a thought... BUT... if one were to build a door using 1/2" oak for the frame, properly joined and covered (both sides) in pressed hardboard (peg board without the holes), wouldn't that resist warp? I know hardboard isn't easily warped but it does NOT like water...so it would have to be covered in epoxy/paint or in this case, Duraback....
Or another theory or way of putting it...the less wood in the door, the less it will warp....especially plywood?
Again, just a thought...
elmo wrote:I have run into a snag. My door is warped. I went out of my way to make sure it didn't lean on something and was always flat, but I have about 1/2 inch warp.I have it off the trailer now with some weight on it. How long should I wait before I try to put it back on?
I think I could of made it water proof the way it was by double sealing, but I would rather have it the right way. I dread the thought of making a new door, besides I would have to order another gallon of Durabak.
Spoon boy: Do not try and bend the door. That's impossible. Instead... only try to realize the truth.
Neo: What truth?
Spoon boy: There is no door.
Neo: There is no door?
Spoon boy: Then you'll see, that it is not the door that bends, it is only yourself.
Users browsing this forum: Google [Bot] and 5 guests
