Sos Houston - Voyager Has Technical Problem
Postby tonyj » Fri Jul 27, 2007 10:30 am
No picture currently, but I can get one this weekend if you want. I used a center mounted handle operating two side latches. I ended up surface mounting the latch assembly on the inner skin of the hatch and routed a small pocket hole in the side reinforced with a door lock plate.
Yeah, that description is as clear as mud. I'll get you pictures this weekend.
I only discovered that rod could be removed after I got mine and discovered I needed one 1/4 inch longer. Stupid ruler. Stupid measurer. Stupid 1/4 inch.
tony
tonyj
Images: 160
