Don’t use a catalytic heater inside the cabin.
benzu wrote:Thanks Dale for the wealth of information,Don’t use a catalytic heater inside the cabin.
Chuck, Why not?
I have a catalytic heater for the inside, I thought if I followed the instructions I'd be safe. It says that the sides and bottom of heater has to be 6 iches away from something cumbustable and 14 inches from the top and 30 inches from the front. It also says to vent, which I have a fantastic fan up top and two windows on either side. If I crack each one a bit I would assume that would be enough.
Mike
goldcoop wrote:Classic Finn wrote:So you folks are allowed to install your own gas lines onto trailers or tears? Here this type of work must be done by professionals ..and they must be licensed and qualified to do it..
Strict Laws Again..but its for safety.
Classic Finn
Heikki-
I think this falls into the "it's easier to be forgiven than ask permission" catagory![]()
BUT it does bring up a good point, don't attempt something unless you are knowledgable AND comfortable doing it.![]()
Coop
Dale M. wrote:
Catalytic heaters produce carbon monoxide....
In a catalytic heater, the chemical reaction of oxidizing (burning) natural gas or propane is slowed to about 65% of normal, resulting in a safe, flameless source of radiant heat. ...
<snip>
... The only by-products of combustion (other than heat) are carbon dioxide and water vapor. Carbon monoxide, a result of inefficient combustion, is not measurable.
capnTelescope wrote:Maybe we can hear from others who have used cat heaters in their tents or TDs and lived to tell the tale.
Ah yes , The good USAClassic Finn wrote:So you folks are allowed to install your own gas lines onto trailers or tears? Here this type of work must be done by professionals ..and they must be licensed and qualified to do it..
Classic Finn
benzu wrote:Another question regarding the propane tank. Is it o.k. to have the propane tank in the same box as the battery and wires or is this a bomb ready to happen? I can put a seperation in the tounge box to seperate the Propane tank from everything else but not sure if that is enough protection.
Chuck, Why not?
Mike
