Eliminate the Galley Hinge!!!!
Postby Guest » Tue Mar 01, 2005 11:06 am
Dave,
Thanks for the link, if I go that route... I'll anodize it myself.
Everyone that I've checked with so far, isn't willing to do such a small request, they have outrageous minimal orders based on volumne.
Guest
Galley hinge
Postby An Ol Timer » Tue Mar 01, 2005 1:29 pm
If the pin that the hatch pivots on has a slotted opening then the hinge can slide forward to seal against a seal that is imbedded in a slot and it would allow the hatch and the roof to come together eliminating all but the line between them. Just a thought!
An Ol Timer
Postby Guest » Tue Mar 01, 2005 4:25 pm
I like that O.T.
Here's a shot of the side wall and hatch with the gutter drain system and double compression bulb seal that I described.
Guest
Postby fornesto » Tue Mar 01, 2005 5:50 pm
Well, I've abandoned this concept 'cause my hatch is almost done, but on my next teardrop ( :twisted: :? ) I would definitely consider it. I think the right way to do it is to steam and bend 1" x 4" oak on end and do the slot thing mentioned by an 'ol timer. With the right set-up, it would be beautiful, especially on a woodie...
fornesto
Hingeless Hatch
Postby An Ol Timer » Tue Mar 01, 2005 10:32 pm
After thinking about it, I thought that I'd post this other photo that I've been working on. It should be self explanatory. The drawing is to a scale of 1/4" skin over 2" frames. I found that you would only have to move the hatch back a little over 5/8" for the joint to clear as the hatch is raised up. Also when closed the joint would be stronger with a series of locator pins as well as the pivot rod. With both the rod and the pins one should expect a fairly stable joint. With a channel routed out for the seal you should be able to close the joint in the outer skin completely.
An Ol Timer
Postby asianflava » Tue Mar 01, 2005 11:44 pm
I see what you are talking about now. Looks cool, it will give the rear a clean look. You could also use draw latches to snug up the hatch.
asianflava
Postby Ron Dickey » Thu Mar 03, 2005 9:12 pm
gosh .... :shock: I have never seen you guys go at it so intense before.
Maybe you should do in the hinge all together and make it slide in to the top like this :twisted: and then add a roll out canvas cover to if you hit your head it will not hurt so much?
:cry: I just wanted to play too.
Ron D.
173882......173887
Ron Dickey
Images: 787
