Gally counter
Postby 2bits » Mon Sep 01, 2008 1:13 pm
Ian, I like the stainless look, very nice.
RHL, since you are thinking about natural, here is a pic of mine, I have three coats of spar urethane on it now just for construction, and plan on a few more once I get the face frames on and into the finishing stage and can take my time getting a really nice and durable finish. I thought about getting some of that bar top stuff, but it will depend on $$$ when the time comes!
Thomas
2bits
2bit Member
Postby rhltechie » Mon Sep 01, 2008 1:31 pm
thomas,
your natural wood looks very nice! i am still torn over which look i like most....but..i have time!
rhltechie
Images: 49
Postby john » Mon Sep 01, 2008 3:01 pm
The big box stores often discount flooring when discontinued and very little remains in stock. I used hardwood flooring glued to 1/2" ply on my counter.
They only had 1 box but that was all I needed. Cheap, prefinished and good enough to walk on.
Good luck :thumbsup: :thumbsup:
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby JohnnyG » Mon Sep 01, 2008 7:52 pm
I just spray painted 3/4 inch plywood with splatter spray paint. Then about 3 coats of poly and stainless steel edging for that 50's look. It did turn towards yelo but I still like it. I get lots o' compliments on it, my tear is not done yet.
JohnnyG
Images: 67
Postby Steve_Cox » Mon Sep 01, 2008 9:10 pm
Hi Mandy,
Here's yet another one.
Steve_Cox
Images: 196
Postby Arne » Tue Sep 02, 2008 7:12 am
The fancier you get the more the t/d weighs.... the more it weighs, the less mpg you get.....
I really like the gallies with cabinet doors, tiles, stainless, etc.... but I kept everything as light as practical to keep the weight down.
so, you pay your money, and take your choice.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Nobody » Tue Sep 02, 2008 10:59 am
My galley counters (& side tables) are made of 3/4" birch plywood. I just added a solid wood edge trim to the counter tops, applied a light 'Honey Maple" stain & covered with several (numerous??) coats of spar urethane. For 2yrs now it's taken everything that can be thrown (or spilled :roll: ) on it with little apparent damage. Water/food spills are wiped up right away & any minor rubs/scuffs can be 'fixed' with a little lemon oil polish. Was easy to do & so far it's easy maintenance :thumbsup:
Harvey -
Nobody
Images: 342
