Ideas please for a drop-floor mechanism
Postby S. Heisley » Sun Nov 30, 2008 10:52 am
Here's another idea: Instead of dropping the floor in the center, why not have pull-out trailer sides (in the door area, from the front to the wheel) with a drop floor in the pull-out part? That way, you end up with a walking/dressing aisle on either side of the small trailer's bed and a person is less likely to trip or fall on a recessed floor. It might be less weight, too.
Postby john » Sun Nov 30, 2008 12:55 pm
Going with the one man operation condition got me thinking about pop ups.
Perhaps a hand crank similar to the ones used on boat trailers could be mounted on the tongue. From there a cable could run under the trailer and then branch off to the necessary corners or sides of the drop floor.
Although likely more complex than the spring method there may be some unexpected complexity in getting the springs to raise the floor uniformly.
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby wannabefree » Sun Nov 30, 2008 8:52 pm
Go to www.surpluscenter.com and search for linear actuators. The problem will be keeping them in sync.
Their prices seem cheap until you start talking postage!
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby bobhenry » Mon Dec 01, 2008 9:50 am
RED NECK FLOOR LIFT
Inflate 1 large innertube to lift floor unpin transport lock. Deflate innertube to lower. Reverse order to raise.
Total cost $10 - $15 for good used truck or tractor tube.
:D :D :D
Postby Elumia » Tue Dec 02, 2008 2:33 am
A scissor jack would make a nice operator. Could run it with an electric drill or a speed wrench. If you were so inclined you could put in a reversing motor - maybe from a power window? Seems to me, that one jack should opperate a small drop floor. I would mount it on the center of one of the long sides - possibly use an angle frame to support a plywood floor. It would probably need a guide opposite of some sort. Guides could come up into cabinetry
Side walls could also be fabric. Use a bungee cord loop in the middle to create tension so the sides go in when the floor goes up.
If it rests on the ground, how do you ensure it is level other than choosing a level parking spot?
Mark
Elumia
Images: 15
Postby moreforles » Mon Dec 08, 2008 1:00 pm
metal frame with holes to slip pins through to hold it in place while raised and down. lifting mechanism... cable system attached to 12 volt winch from harbor freight for $79.
If designed right (meaning by someone smarter than me) with an additional access port... when not in use raising or lowering the drop floor, the winch could be used for any other winching needs.... mount on swivel plate on tongue.
planning on enclosing most of the tongue on mine, use the inside space to hold battery(s), power inverter, propane tank and winch (if I go with adjustable floor, although will most likely use a permanatly dropped floor if I go with a dropped floor)
moreforles
Postby angib » Sun Dec 14, 2008 10:20 am
Well, John, here's your idea modelled - and I think it should work just fine.
The springs are rubber-cored ones from McMaster Carr (8433K21):
Four of them provide ~90lb upthrust in the raised position (about 30lb more than the drop floor weighs) and ~130lb upthrust in the lowered position. The (red) 'strings' are 3/16" diam and run round small (blue) boat cheek blocks.
When the trailer is being towed, the floor is held up with one (adjustable) over-centre latch on each side (McMaster 1525A31):
To lower, undo the two latches, gently step inside, the floor will go down (unless you weigh under 60lb!) and you insert one pin (not shown) either end to lock the floor down.
The drop floor might tend to tilt to one side and jam on the way up or down - but a judicious tap with the foot should cure that.
The only downside is that these mechanics take up an extra 1-2" all around the drop-floor, so bang goes my chance to fit the trailer's frame tightly around it.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby john » Sun Dec 14, 2008 12:42 pm
I'm glad to be of help. :)
Your rendering is more compact than what I had in mind. Better. Nice!
Are you building a camper?
Penomeli ikibobo
john
john
Images: 261
Postby Mini Renegade » Sun Dec 14, 2008 2:55 pm
angib wrote:Well, John, here's your idea modelled - and I think it should work just fine.
Andrew
very similar operation to a 4 poster vehicle lift but they have hydraulic rams to shorten the cables that are run around pulley blocks on each end.
You could always try a length of threaded bar as the actuator. One end fixed and the other end moving up and down when turned, could be accessed with a speed brace from the front/ side of the trailer.
If evvr tha dus owt fr nowt, allus do it fr thissen
Mini Renegade
Postby starleen2 » Sun Dec 14, 2008 3:03 pm
Andrew
I know this is a little off topic - but do I see some sort of pop up mechanism? I know it's for a dropped floor but could be adapted for the reverse
starleen2
5th Teardrop Club
Postby angib » Sun Dec 14, 2008 5:36 pm
starleen2 wrote:do I see some sort of pop up mechanism?
Probably not - a pop-up has to be external, so that water flows off it, whereas this is internal and so nearly impossible to seal.
But the same springs could be used for a lifting Vardo roof, for example, instead of wires and a winch.
Andrew
angib
5000 Club
5000 Club
Images: 231
