Conestoga wrote:I love wool. I'm considering making "soft paneling" from wool for the interior walls and ceiling. These could be taken out to air dry or be replaced with minimal effort.
Hi Conestoga. Yes, the good time proven yurt.
More research required to work out how they moth proofed those things...that would be my only concern with the soft paneling idea. Although maybe not such a concern if it's an interior cover. Several natural oils (lavender, eucalyptus) are supposed to repel moths so maybe a little sachet during the off season. Sprigs of lavender hung near doorways are supposed to work for repelling flies as well.
Suppose it depends what you're cooking and when you last thought to refresh the potty...
Noticed you're in PA. To keep the source list in one thread, the place I got my bedding wool batts from in PA is West Earl Woolen Mills, no website, phone Elva at (717)859-2241. $6.40/lb batting as of fall 2009. Easy to make felt...just friction, dishsoap and hot water, air dry. Might be considerably cheaper if one only needs a teardrop's worth....
As far as I can work out, the advantage of styro/polystyrene is the added structural rigidity it would lend to a ply sandwich, which you wouldn't get with a wool filler. Not sure how much of a drawback this would be.
One thing I liked about the thought is that it may be possible to lay felt in between the spars (think that's the correct term for the framing pieces) and the interior skin, thereby (big perhaps) reducing the temperature conduction of screws and condensation on the interior wood when it's cold outside and warm inside. One could drill screws right through the warm wooly blanket. Would the wool become moist where it meets the screw?
Maybe I need to do some test pieces...
On a slight tangent, had spent some time looking into non-toxic things to use in my home. Real (homemade) milk paint was something I played with. Smells sweet...lime and curdled milk (the lime completely neutralizes the honk of the soured milk). Supposed to be fairly durable in external applications because of the strength of the casein bonding but haven't tried it outside yet.
My little fellow has a few chemical sensitivities (chlorine is very noticeable), so anything questionable needs to be well aired...sometimes having a canary is a useful thing...
Edit: Forgot to say thanks for the links...Thanks!
