What to use to skin all steel tubed frame?
Postby emiller » Thu Mar 17, 2011 8:56 pm
.063 is very thick and heavy. But that is the only thickness I have found for 5 wide. It is what I used on my 5 wide I sold last year. It will make a curve as you can see on my avatar
emiller
Images: 157
Postby emiller » Thu Mar 17, 2011 8:57 pm
Here is a better picture of my 5 wide.
emiller
Images: 157
Postby Siouxgirl2 » Sat Mar 26, 2011 10:36 pm
emiller wrote:Don't use tape in Phoenix use the rivets instead. I bought my 4x10 painted sheets from Industrial Metal supply for the teardrop and 4x10 painted sheets from United Aluminum. the 4x12 unpainted sheets I got here in North Phoenix. I live off of Union Hills and Central, pretty far from you. I will be here working on my vintage trailer Saturday and Sunday mornings. I usually get home from work around 1:30 pm also Monday through Friday.
Would you mind telling me if you have used the tape or is there a reason to not use the tape? I know the heat is an issue but I've been seeing alot of trailers around here lately and it looks like they may have used the tape. Anyway... I wondered if this was just your thought or if you have heard of or experienced a negative using the tape in Phoenix or in extreme heat. Thanks again for your experience and advice.
Siouxgirl2
Images: 69
Postby Siouxgirl2 » Sat Mar 26, 2011 10:44 pm
Just saw your new posts and pictures. It looks great. Very nice to know that that size is workable. I'm still deciding what approach to take. I found some that I can get locally but it is unpainted or mill so what to do??? I have to order from out of State to get painted.
Siouxgirl2
Images: 69
Postby CARS » Sun Mar 27, 2011 8:58 am
Siouxgirl2 wrote:Just saw your new posts and pictures. It looks great. Very nice to know that that size is workable. I'm still deciding what approach to take. I found some that I can get locally but it is unpainted or mill so what to do??? I have to order from out of State to get painted.
Paint it yourself, or take it to a body shop to have it painted.
Chris'
Autobody
Restoration
Service
CARS
Postby Siouxgirl2 » Sun Mar 27, 2011 12:46 pm
Yeah... I suppose your right!! Simple answer... paint it yourself. I guess I was trying to save myself that step in the long run. Thanks for that little reminder.
Siouxgirl2
Images: 69
