Help!!! I just can't read any more!!!! Lol
Postby Postal_Dave » Tue Oct 11, 2011 6:45 am
I have a Nissan Versa and it says the same thing as your Yaris, Not For Towing. The reason is that our cars are Very light weight, not because of the transmission.
So picture you're going down hill on a wet road and you need to stop. You hit the brakes and 1,000 pounds of trailer is pushing from behind. You're probably going to spin and jack knife.
Build a light weight foamy and/or put trailer brakes on. Trailer brake kits are about $500 from Northern Tool.
Good luck with your build.
Dave
Never argue with an idiot. They will bring you down to their level and beat you with experience.
Postal_Dave
Images: 73
Postby bobhenry » Tue Oct 11, 2011 7:08 am
Postal_Dave wrote:I have a Nissan Versa and it says the same thing as your Yaris, Not For Towing. The reason is that our cars are Very light weight, not because of the transmission.
Dave
Postby bobhenry » Tue Oct 11, 2011 7:14 am
"NOT RATED TO TOW"
Postby Postal_Dave » Wed Oct 12, 2011 3:53 am
Chicken Little hahaha That's funny. :lol:
Of course you do realize that your Scion XB weighs almost 1,000 pounds more than his Toyota Yaris. :thinking:
That will make a huge difference when towing a camper, and being able to Stop a camper.
So it's not that I'm chicken, I'm just not reckless.
Postal_Dave
Images: 73
Postby bobhenry » Wed Oct 12, 2011 7:30 am
http://www.toyota.com/yaris/specs.html
short exerpt WEIGHTS AND CAPACITIES
Curb weight (lb.) 2295
EPA passenger volume (cu. ft.) 84.4
Cargo volume [1] (cu. ft.) 15.3
Fuel tank (gal.) 11.1
Seating capacity 5
2006 Scion xB Exterior Features
-Body color front and rear bumpers -Driver and passenger power body color door mirrors -External dimensions: overall length (inches): 155.3, overall width (inches): 66.5, overall height (inches): 64.6, wheelbase (inches): 98.4, front track (inches): 57.3, rear track (inches): 56.3 and curb to curb turning circle (feet): 36.1 -Complex surface lens halogen bulb headlights -Luxury trim alloy look on doors and alloy look on dashboard -Pearl paint -Fixed rear window with defogger and constant -Tinted glass on cabin, rear and side -Weights: curb weight (lbs) 2,415
Curb weight on the XB is only 122 # Heavier unless your are adding in me and the bride and then we are getting closer to your number :lol:
I get in trouble every time I post stuff like this. I am trying to get everyone killed etc. I towed Chubby with the Scion almost 1500 miles to several gatherings as it was the newest and most dependable car we had at the time. I now have a D1500 fullsize Dodge P/U with the 6 cylinder in it . We now use it because we have it and we can now haul firewood and messy grills and coolers and tote boxes in the bed of the truck. However, back "when", we used the scion. I felt real bad when I finally had Chubby weighed and found out he was 1830 # loaded ready to camp. All that behind a 2415 pound 4 cylinder car. :oops:
I never felt reckless, but I guess I was,
cause I never had a wreck! :rofl2:
Postby sagebrush » Wed Oct 12, 2011 12:20 pm
From 2007 Toyota Yaris Hatchback owners manual
Towing capacity (except for Canada)
Toyota does not recomend towing a trailer with your vehicle
Towing capacity (for Canada)
318kg (700 lb.)
towing capacity means the maximum gross trailer weight.
:thinking: Are Canadians smarter or better drivers than Americans?
Or are there too many lawers in America and Toyota is covering their rear-end? :thinking:
The biggest factor in safe towing is THE NUT BEHIND THE STEERING WHEEL
We ain't skeer'd of the dark!
Living large in a small way!
sagebrush
Images: 161
