by Dale M. » Fri Mar 16, 2007 11:28 am
The problem may not be the jack(s) when it comes to stability, it may be how you "setup" trailer on jacks....
Process I have uses over the years is to disconnect trailer from tow vehicle, lower front tongue jack to below level for trailer, put rear stabilizers in place and then bringing tongue back up to level... This unloads springs a bit and trailer sits on three solid points.... Thus being more stable... To pack up and get ready to leave, I lower tongue jack, take pressure off rear stabilizers and the fold them up, raise tongue with jack and connect to tow vehicle....
I also carry a few wood blocks for "pads" so jacks do not sink into ground and help level trailer if ground is really uneven...
Plus its a faster setup and take down then futzing with individual jacks (against the trailer weight) to level and setup or take down...
Dale
Dale M. on Fri Mar 16, 2007 12:44 pm, edited 1 time in total.
