jack stands
Postby bdosborn » Mon Sep 12, 2005 8:42 pm
I just screwed some leftover pressure treated to the bottom of the jacks since the holes were already drilled in the plate.
Images: 806
Postby Endo » Tue Sep 13, 2005 4:29 am
I mounted mine on a 45 degree angle to the back and sides of the trailer, so when they are folded up they are not as visible.
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby ALAN GEDDES » Tue Sep 13, 2005 12:51 pm
8 or 9 trips this last year and still haven't found a need for them yet.
Alan
ALAN GEDDES
Images: 34
Postby TRAIL-OF-TEARS » Tue Sep 13, 2005 5:02 pm
I have them but don't use them either. The tongue jack is garbage it has lots of slop. So I leave it hooked to the vehicle then put the tongue jack down to minimize the movement.
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
Postby Chris C » Tue Sep 13, 2005 5:11 pm
I don't plan on always camping in my garage or on nicely leveled RV pads in RV parks. So I want a way to level and stabilize the trailer on uneven ground.
Chris :D
Chris C
Postby WarPony » Tue Sep 13, 2005 6:49 pm
I just use regular car jackstands. They have a big footprint (no wobble) and are cheap. Might not look the best but I like em'!! Can also come in handy if the vehicle breaks down.
WarPony
Images: 289
Postby cracker39 » Wed Sep 14, 2005 6:23 pm
I've considered using the jacks that Darren mentioned from NT, having had that type on a Coleman popup. I am also considering the screw post type that Kevin showed. With those, I'd just lower the front past level, put two jacks under the back corners, raise the front just above level, put two under the front two corners, and lower back to level. And, they are cheap. Around $30 for a set of 4 at Wally World.
Dale
cracker39
Images: 233
Postby sledge » Fri Mar 16, 2007 10:43 am
Kinda Like Warpony said, I use a Floor Jack. for a couple of reasons , one it's easy to get under the Teardrop when the ground is damp without getting on the ground., and with the Tongue jack and the floor jack on the low side at the Axle I can level her right up. AND.... I also have that same jack in case I need to jack up the Truck. ...... AND, my Truck and Teardrop both have the same Wheel Bolt Patterns, So..... I can use same spare tire. :thumbsup:
sledge
Images: 26
Postby critter » Fri Mar 16, 2007 11:18 am
Hey Guys,
I am thinking about building my own outa 3/4 in square steel tubing and having it silp into a piece if 1in tubing welded to the frame with hole drilled for a pin in the side and a 3in square plate welded to bottom.Anybody else done this? :roll:
critter
critter
critter
Images: 54
Postby Dale M. » Fri Mar 16, 2007 11:28 am
The problem may not be the jack(s) when it comes to stability, it may be how you "setup" trailer on jacks....
Process I have uses over the years is to disconnect trailer from tow vehicle, lower front tongue jack to below level for trailer, put rear stabilizers in place and then bringing tongue back up to level... This unloads springs a bit and trailer sits on three solid points.... Thus being more stable... To pack up and get ready to leave, I lower tongue jack, take pressure off rear stabilizers and the fold them up, raise tongue with jack and connect to tow vehicle....
I also carry a few wood blocks for "pads" so jacks do not sink into ground and help level trailer if ground is really uneven...
Plus its a faster setup and take down then futzing with individual jacks (against the trailer weight) to level and setup or take down...
Dale
Dale M.
Images: 18
Postby critter » Fri Mar 16, 2007 11:43 am
Hey Dale,
That just what I do also and it works great.i have those little sticky back levels on the camper and thats the way to go i think! :thumbsup:
critter
critter
critter
Images: 54
