GeorgeTelford wrote:Hi Gage
The original question was not as far as I can tell "how did Gage do it?" Just struck me as odd that yousay back to original question and then ignore it yourself.
Mike was wondering
"trying to figure out if one layer of 1/8" plywood is enough to cover the generic benroy? "
and also
"But what if you only have 1 layer of 1/8" luan, and what if you only paint it, instead of putting aluminum or fiberglass on it?"
Aw, you read like Ira. Did you miss this line? "Just the way I did it and it worked for me."GeorgeTelford wrote:Gage
I have just seen your reply, I questioned why you completely ignored the original question, you sure seem arrogant enough to believe yours is the only way.
Why thrash a piece of ply? Use a little common sense and basic knowlege. If you throw rocks at anything, your going to cause damage. Even building a GENERIC Teardrop, you need strength. So 1/8" ply (no mater what type) won't work without alum skin. Even the original Benroy was built as a generic type teardrop also with alum skin for strength. So if your not going to apply alum, then use at least 1/4" ply. But then your going to have problems forming the shape you will need.GeorgeTelford wrote: Of course there are other options, but you completely ignored the original request and stated what you did as though its the only way.
What I did was test it out went out and thrashed a pce of ply to see, Mike repeated the experiment and found the same.
So is that the answer you were looking for? And here I though it was Mike that had asked the question. I guess I screwed up again.GeorgeTelford wrote:Not questioning what you did on yours, only that its total irrelevance to the question posed here.
Gage wrote: I guess I screwed up again.![]()
Have a good day.
Oh brother, I give up.GeorgeTelford wrote:Hi Gage
Why thrash a pce of ply?, to show that you do not HAVE to have an aluminium cover.
Even with an aluminium skin a smooth rock will do damage and a rough rock will gouge, so an alum skin is offering no extra protection, in fact the alloy skin will be harder to repair than the ply alone.
After we checked it out, Mike is adding this to the generic build
My recomendation as I posted in the generic build thread today was either 1 layer of baltic birch or two layers of luan. (All 1/8" of course). This is designed to be painted....
