aggie79 wrote:citylights wrote:TPMcGinty wrote:woodywrkng wrote:So condensation doesn't occur in the bottom of the mattress..
jonesnforcampin wrote:I don't plan on insulating my walls. But then again I plan on doing either two pieces of 1/2" or two pieces of 3/4" plywood for my walls. I will be insulating my rood and floor just because there will already be voids based on my design. But if I insulate my walls I will just be losing precious interior space. I plan on my family of five sleeping in there, so interrior space is at a premium.
Additionally, being here in HOT AZ more windows, vents and fans will probably be better than the benefit of that thin piece of insulation.
citylights wrote:Use a drill and 8 inch hole saw to skeletonize the 3/4 plywood side walls. Stagger the holes to maximize the ventilated space. Maybe use 3 inch door knob hole saw for smaller spaces to fill in. Just make sure to leave a minimum space (to be determined) between holes for strength structure. Use the same hole saws to cut insulation disks for the holes. Skin inside and out with 1/4 inch ply. Instant easy lightweight and super strong insulated construction.
