door ideas
when you put in your doors did you
buy a set
4
7%
cut them out of the side add hindges and seals
40
73%
invent a door
10
18%
totally different
1
2%
Total votes : 55
Postby toypusher » Sun Jan 22, 2006 8:54 pm
Me too! But - You did ask! :shock: :lol:
toypusher
Images: 324
Postby Ira » Tue Jan 24, 2006 9:11 am
Mine are totally nuts.
I copied the shape from someone else here, and I used large Tee-hinges.
The handles are separate, and slide-bolts inside and out act as the locks.
The only thing I can't figure out is how to trim out the top semi-circles. I also want to add a little type of awning effect, something like a rain visor on a car.
Here we go again!
Ira
Forum Storyteller
Images: 118
doors
Postby Finntec » Wed Jan 25, 2006 5:33 pm
We cut them out of the sides!
Former owner of a '05 Homebuilt TD & '87 Scamp
2012 Home built 10' Teardrop.
Finntec
Images: 28
Postby goldcoop » Wed Jan 25, 2006 7:09 pm
Ira wrote:The only thing I can't figure out is how to trim out the top semi-circles. I also want to add a little type of awning effect, something like a rain visor on a car.
Ira-
How 'bout something like this:
http://www.pacerperformance.com/pages/products.asp?id=2
No Lip - Side Mount
• For fenderwells without a mounting lip such as those
that have been cut to accommodate an oversized tire.
• Attaches to side of fender.
• 1/4" thick. Extends width of fenderwell by 2-1/4".
Model Number
52-170.... Black 2 pc. kit 58" lengths.
52-169.... Black 50' bulk roll.
Hey it's surface mount, flexible rubber!
Mount it up high enough on the sides of the Crab for the door to clear...
Coop
goldcoop
Images: 32
Postby Ira » Thu Jan 26, 2006 9:32 am
Ira-
No Lip - Side Mount
Model Number
Coop
THAT'S THE STUFF! THANKS, COOP!
I went to the auto store looking for WINDOW rainguards, but never thought of looking DOWN.
You think I can find this in a store locally?
(Hey--never mind that last part! They have a dealer locator list on the site! THANKS AGAIN, COOP!)
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby goldcoop » Thu Jan 26, 2006 9:43 am
Ira-
Glad to help!
BTW if you can't find it locally, you CAN by direct from Pacer!
I used flare extension for a continuous corner trim on the C'tear.
Couldn't find a 50' roll from any of their dealers, called 'em up, explained my dilema to them, they hooked me up!
Coop
OH JC Whitney sells their stuff too!
goldcoop
Images: 32
Postby Ira » Thu Jan 26, 2006 10:16 am
The two shorter lengths would be fine for me--and you're pretty sure it'll bend to my radius?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby goldcoop » Thu Jan 26, 2006 10:28 am
Ira wrote:The two shorter lengths would be fine for me--and you're pretty sure it'll bend to my radius?
Ira-
I'm reasonable sure!
This stuff is kinda like a limp ahhh, eemm, well noodle!
Take a look at the top front radius on my trailer, 22".
It is made for fender flare extensions, so if your door radius is close to a car/truck fender opening (looks like it is), you should be good to go!
Coop
goldcoop
Images: 32
