Steve Frederick wrote:I'm building everything as a sandwich these days. Floor, walls, even bulkheads and cabinet frames.
The next T/D I do for myself will be built with 1/8" skins, instead of my usual 1/4" skins.
When I built Mike's 'Diner, I weighed a wall panel (4'-6"-by 11'). It weighed about #70, the same as a 4-by-8 sheet of 3/4" ply!
The sandwich is 1/4 ply, minimal 3/4 framing and foam, then 1/4 ply.
Floors are 3/8" ply on the top, foam/framing, then 1/4 ply on the road-side.
Some will disagree with sealing the bottom. I do mine in wood, then epoxy/paint. No voids for moisture to get in. Just the way I do it.
As MadJack says, "Your Mileage May Vary"!
SteveH wrote:.................
Questions...have you ever put the pencil to the cost of your built-up panels vers straight plywood? Also, have you ever kept track of the man hours required to build a typical wall panel?
Just curious. Thanks.
jeffwholmes wrote:Thanks steveH, I was thinking about a 2” radius.
When I build my frame should I make it 102” so I will have a 3” over hang at both ends?
Will that be enough room to make my radius so it hides the frame, and if so will luan bend around that?
Thanks Jeff.
jeffwholmes wrote:I am going to estimate my overall weight at 1500 lb. / 682 kg.
Strength needed is 0.5 x 1500 = 750 x 48 = 36,000.
The 2”x2” is only rated at 20,900 lb/in vertical capacity, think I could use 2.5”x2.5” it is rated at 35,600 lb/in vertical capacity.
SteveH wrote:
Steve,
Steve Frederick wrote:SteveH wrote:
Steve,
Although I can put together a set of walls, ready to install, finished inside and out, in about 30 hours time, spread out over a couple of weeks , the answers to the questions don't matter to me.
I'm not being a wise guy, but, it's just my thing. The first T/D I built required a larger panel than I could get easily. I had the materials on hand, so I developed a way to make larger panels that I could leave exposed. The next one was an experiment with thinner ply. Framing was required to keep the thinner wood rigid..Folks liked it..
Even if I never sold a trailer, I would still do it this way..Artistic preference, I guess.
You know, why would anyone build something that is otherwise mass produced, and cheaper? Must be the art??
