Door trim & weather stripping????
Postby Boodro » Sun Jun 12, 2005 9:48 pm
UUUUUHHHHHH , I coud'nt say , as I claim temporary insanity & old age ! :fb :CC :crazy: :crazy: :crazy:
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Postby The R/C Man » Mon Jun 13, 2005 12:45 am
Thanks Guys!
I need to bend it to a 6" radius. I guess I can always use some heat to coax it a bit if it doesn't want to go.....
Greg
Over time science has shown that the simplest answers are usually the correct ones.......
The R/C Man
Images: 36
Postby madjack » Mon Jun 13, 2005 9:44 am
...R/C, try a search for annealing. I turned up 15 hits that just about cover it all
my own personal results with annealing show that if done correctly you can bend(& beat) your trim into most radius's and remember that you can anneal your aluminum more than once if necessary
p.s. remember you will need a good rubber mallet or dead blow hammer and a block of hardwood as a dolly, I also found the "candle" method works well if you don't have the eye for the plain yellow flame method...remember YMMV
Postby Guest » Mon Jun 13, 2005 10:01 am
Hey,
Speaking of weather stripping and what not around the doors...
I've got a canned ham in the back of my shop right now... In for glass replacement.
I noticed that it has a screen door right behind the door. It's hinged with offset hinges, so that both doors pivot on the same pivot point.
Has anyone done something similar on their teardrop?
Guest
Door Seal
Postby Guest » Mon Jun 13, 2005 10:44 am
There is stuff called Tacky Tape that makes a very good seal. It will also help hold in the door to the wall.
Merlin
Guest
Door Seal
Postby Guest » Mon Jun 13, 2005 10:45 am
Merlin
Guest
