From the Green Lantern Build
starleen2 wrote:Sanding is done – now for the first color coat – you guess it – ALL green. Did away with the two toned scheme and went with all Coleman green. The front and rear graphics will break up the color
Now to play the waiting game for the paint to dry - then install the windows door and next comes wiring the trailer harnesses and lights
starleen2 wrote:Well folks here’s the secrete – The paint is from Tractor Supply Company and its Valspar Tractor & Implement High Gloss Enamel, Oliver Green. It a close match to coleman green. I used it on the interior bedding platforms and its super tough – I’ve sprayed it with water, armor all, and even sanded it – tough stuff once it’s cured. I guess it has to be to used on farm equipment. It’s an oil based paint so it’s kinda a mess to deal with as far as clean up – but it’s defiantly a bulletproof finish (Please don’t test it by firing bullets into my camper!) It takes a while to cure – but it seems to level itself out – and I applied it with a foam roller!
As the camper has weathered some - I can say that this paint is
SUPER durable - I have scrubbed squished bugs off the front from towing and the paint is rock hard - The only drawback is that it does take at least a day or two to fully cure.. . . And Yes, its still that glossy!
