Well, I finally got the other side on but I'm still not happy with the way it turned out.
![Mad :x](./images/smilies/econ_steamingmad.gif)
I called DAP who said the good news was that I could put another layer on and it would reactivate what I had on before. I make sure the temperature was correct, rolled another layer of the contact cement on and waited for at least an hour as per instructions. It still didn't feel right but I put it on anyway. I got mixed results but enough of it stuck that I can't take it off again and I doubt if it will in it's lifetime.
![Sad :(](./images/smilies/econ_sad.gif)
There will be enough of it connected around the door and edges that I think it will be good enough for who it's for. I will not recommend to use the water based DAP contact cement though the oil based stuff worked well even if I had to have plenty of ventilation when using it.
I bolted the body to the frame and am in the process of mounting the fenders but they will have to come off when painting it. I'm debating to either paint the fenders the same color as the sides or paint them black. What do you all think?
![Thinking :thinking:](./images/smilies/econ_thinking.gif)
