What Do You Use For Hatch Supports??
Re: What Do You Use For Hatch Supports??
Postby Woodbutcher » Mon Sep 03, 2012 3:20 pm
bigblockbarry wrote:Do those bend in when shut? I have seen those on his website but I didn't want the spring part swinging around scratching everything when in transit.
They do bend in when closed. There is a wire that runs thru them. Also they only pivot 90 degrees from the mount so they stay put.
Woodbutcher
Postby bigblockbarry » Mon Sep 03, 2012 6:26 pm
Maybe I will give these a shot.What I have works but I would like some that mount solid to the hatch and the main body.Thanks WB
Barry
bigblockbarry
