(The Puffin) New Tiny Trailer
Postby NightCap » Tue Jun 12, 2007 4:06 pm
steve wolverton wrote:Lazy Sunday and I've done a few things on the camper. I installed the dropped floor, installed weather stripping around the doors, installed the door latch, and about to install the electrical hatch.
Dropped floor installed and epoxied in place. If you notice on the side closest to the door I had to install a 1" strip because my original measurements were off. Actually, they were spot on, the Harbor Freight spring hanger bolt was in the way, so I had to make my dropped floor 1" narrower than the original. Standing on the dropped floor there is about 1" of clearance above my head - wearing a cap - and shoes. :thumbsup: I'm 6'1" tall.
I am building my TTT in my mind and am wondering how close the dropped floor is to the doorway? Can you step right into the dropped floor from the outside of the trailer in one step? Is it easy? And with no dropped floor in the bathroom how do you take a leak? I don't think macho Steve would sit to pee.
I am thinking of making my dropped floor all the way across the trailer from rail to rail. If I could figure the frame delima out I would make it go from wall to wall. So if you stand in front of the toilet you would be standing on the sunken floor. Make sense?
Oh, and I would be welding a 16 gauge box into the large opening.
#1 - 100% Done #2 - 100% Done Thinking about #3
NightCap
Images: 259
Postby steve wolverton » Tue Jun 12, 2007 4:31 pm
NightCap wrote:I am building my TTT in my mind and am wondering how close the dropped floor is to the doorway? Can you step right into the dropped floor from the outside of the trailer in one step? Is it easy? And with no dropped floor in the bathroom how do you take a leak? I don't think macho Steve would sit to pee.
It measures 16" from the edge of the dropped floor to the outside of the camper. I don't have any problems stepping into it. Lisa doesn't have any problems either (she's 5'4"), but Analisa has a difficult time (5'2") so she just steps up into the camper, and then down into the dropped floor. All of my girlfriends are short enough that they can stand on the floor inside the camper.
As for me standing in the bathroom, it's not a big deal. I'm only in there for 30 seconds or less. ;) I just bend my head down and hold myself up like I'm leaning on a wall at a urinal.
NightCap wrote:I am thinking of making my dropped floor all the way across the trailer from rail to rail. If I could figure the frame delima out I would make it go from wall to wall. So if you stand in front of the toilet you would be standing on the sunken floor. Make sense?
I would highly recommend taking the dropped floor the entire width of the frame like you suggest. I didn't because of weight (my dropped floor box is 3/4" ply) but if I could do it again I'd make it out of 1/2" ply and extend the full width.
I understand what you're talking about the dropped floor in the bathroom - sounds like a good plan.
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby NightCap » Tue Jun 12, 2007 4:50 pm
By the way, thanks for the answers.
I was thinking half and half on the bathroom floor but that might not work cause the toilet will be too high. I'll have to take measurements when the time comes. Your way sounds doable since I am the same hight as you. Thanks again.
NightCap
Images: 259
Postby steve wolverton » Tue Jun 12, 2007 5:02 pm
NightCap wrote:I was thinking half and half on the bathroom floor but that might not work cause the toilet will be too high. I'll have to take measurements when the time comes. Your way sounds doable since I am the same hight as you. Thanks again.
You could always build a little stand for the toilet. Remove the toilet and you have a shower pan. :)
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby NightCap » Tue Jun 12, 2007 7:04 pm
I guess there are plenty of options. Sure makes life interesting. :D
NightCap
Images: 259
Postby Donutboy » Tue Jun 12, 2007 10:30 pm
This whole thread has almost convinced me, and more importantly my wife (also a "Lisa") to build one. But we also need room for our two kids.
I'm thinking of putting bunk beds where you have the bathroom/front cabinet, with storage below the lowest one. The mattress for the lowest bunk could be moved and placed on the top bunk temporarilly to get some cabinet space across the front if needed.
Today I was also thinking about dropping the floor from frame rail to frame rail. Putting the toilet against the left wall opposite and facing the doorway. Maybe with walls that extend from the left wall out to the edge of the toilet (roughly 18" I think) and a shower curtain on a u-shapred rod that could be moved around for privacy. Then you could stand in the dropped floor to pee, as was discussed earlier.
Another thought--an 8'x5' trailer would give a little more room between rails
One other question. You mentioned your tow vehicle is a 4-cylinder. How much of a drop do you see in the MPG when towing this?
Thanks much for all the posts--I stumbled on this thread quite by accident and have been thinking of building one of these non-stop ever since.
Jerry
Retro-Kamper
(Puffin for Four)
Donutboy
Images: 126
Postby steve wolverton » Tue Jun 12, 2007 11:12 pm
Donutboy wrote:I'm thinking of putting bunk beds where you have the bathroom/front cabinet, with storage below the lowest one. The mattress for the lowest bunk could be moved and placed on the top bunk temporarilly to get some cabinet space across the front if needed.
I don't see why that wouldn't work. They would work as bulkheads as well.
Donutboy wrote:Today I was also thinking about dropping the floor from frame rail to frame rail. Putting the toilet against the left wall opposite and facing the doorway. Maybe with walls that extend from the left wall out to the edge of the toilet (roughly 18" I think) and a shower curtain on a u-shapred rod that could be moved around for privacy. Then you could stand in the dropped floor to pee, as was discussed earlier.
Yup, I think NightCap was right on about that one.
Donutboy wrote:Another thought--an 8'x5' trailer would give a little more room between rails
A 5x8 trailer would be really nice for a Puffin type of camper. The reason I didn't get one was the cost. I built mine on a tight budget, but I would have loved to build it on a 5x8 as I could use the larger dropped floor. 5x8's are heavier though, bigger wheels/tires are nicer too, but I wanted to keep the weight down, and I'm quite happy with my shade under 800 pounds.
As for the mileage drop, to be honest I really have no idea as I don't track it. I pull my camper at 60mph, but I've been to 75+ when passing. I just like to tow slow. I'll try to make a mental note to check my mileage on my next trip.
Donutboy wrote:Thanks much for all the posts--I stumbled on this thread quite by accident and have been thinking of building one of these non-stop ever since.
Thanks for reading through all my ramblings! :thumbsup: I've changed up a few things since I built it, but I'm quite happy with my design. Now it's mostly cosmetic and fun stuff that I'm tinkering on.
Oh, and welcome to the board!
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby steve wolverton » Tue Jun 12, 2007 11:16 pm
I got my speaker boxes painted and installed the speakers. I don't have a permanent stereo/cd player yet so I'm using an old Sony Tuner/Amp which is really, really, *REALLY* too much amp for what I need.
Speaker boxes textured with speakers mounted. 6x9's.
Same shot with flash off. You can see the storage area above the bed. There are only 3 storage holes visible, but there are 4 up there. That's my arm visible in the top of the picture too as it's really tough to get these shots in an 8' camper. I have to hold the camera behind me over the AC area and hope I'm pointing it correctly.
Last edited by steve wolverton on Tue Jun 03, 2008 4:46 pm, edited 1 time in total.
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby NightCap » Wed Jun 13, 2007 1:28 am
It of course looks great. Where are you putting the controls etc for the sound system?
NightCap
Images: 259
Postby steve wolverton » Wed Jun 13, 2007 8:52 am
NightCap wrote:It of course looks great. Where are you putting the controls etc for the sound system?
I'm going to put the tuner/amp in the storage shelf above the bed next to the reading light/dimmer switch. Since I have mirrors everywhere, my remotes don't seem to have problems working regardless which direction I aim them. :lol:
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby NightCap » Wed Jun 13, 2007 6:37 pm
Good thing you're not dealing with lazers. eh?
NightCap
Images: 259
Postby SaGR » Wed Jun 13, 2007 6:40 pm
I'm waiting to see the disco ball show up in a picture :D
Building a small bowtop Vardo
Build thread: http://tinyurl.com/yk4hnmd
Generic Benroy: Sold to FIL/MIL
SaGR
Images: 21
Postby Donutboy » Wed Jun 13, 2007 8:13 pm
Or there's always this: http://www.magicfingers.com/
:R
Jerry
Retro-Kamper
(Puffin for Four)
Donutboy
Images: 126
Postby SaGR » Wed Jun 13, 2007 9:10 pm
:lol: :lol:
SaGR
Images: 21
Postby steve wolverton » Wed Jun 13, 2007 9:12 pm
Donutboy wrote:Or there's always this: http://www.magicfingers.com/
Disco ball and magic fingers... Ordered!
This is gonna be so pimp! ;)
Oh, bonus! Over 30,000 views on my Puffin build! Mike is sending me my 3rd T-shirt! Thanks all. :applause:
�veni, vidi, vici.�
steve wolverton
Images: 11
