I have looked at your build site and noted some similarities to my Zephyr...
I have studied your drawing...
I have an observation that might help. It comes from a friend of mine who suggested I reinforce the seam at the front edge where the two forms make a point or sharp edge. This is where some flexing stess will work the seam open if it is not reinforced. The curved surfaces of the roof meeting the side walls hold up better because they don't flex in the same way. The curve introduces a more rigid form. But the straight line of the point lacks this along the lateral seam. So in the pic below you can see I added a spar that matched the angles. I had to think this through but when finished I had a solid surface for mounting and sealing both my inside and outside skins.
I also made a similar piece to strengthen the bottom of the front point because the stress issues are the same.
Let me know what you think... Hope it helps
DEE BEE
