mandy wrote:Ok I just found this stuff yesterday Feb 19th 2009. I wonder if it is really as uv resistant as it says it is. Also is there any drawbacks to using the Poly max stuff? Sid how did it work out for your TD?
Hi Mandy,
Yes, it's UV protection was just fine. The problem with it is that it hates to lay flat when yhe temperature changes. Several people have tried to use it using various kids of adhesive from double sided tape to carpet glue. I skinned mine when the air was cool in November. The next spring when I had it out in the sunshine, it came alive with bubbles and veins and twisting. If you look through my web site album on it you can detect what I am talking about. No type of adhesive will stick to it for any length of time due to the way it changes shape.
The final conclusion from those that have used it is DON'T.
I sold it the following year to a lady friend of ours who is still using it. It's weatherproof, UV resistant and looks good from a distance. But as for a "quality finish", you are not going to get it.
Hope this answers your questions.
Mark
sid n side
"If you're going through hell, keep going......" Winston Churchhill
Side by Side - completed October 2008
