curse of the 1/16ths
Postby kayakrguy » Sat Aug 19, 2006 5:00 pm
Hi folks,.
Hey, what would life be without problems, right? Well just in time, I have a problem. Dry mounting my walls, I discovered that my walls square up at the top to 5' and 1/8 inch wide...and the problem seems to be symmetrical.
Two questions: If I simply cut the roof spars to 5' and fit the walls to those at the top, would the 1/8" make that much difference in lining up the rest of the build? I can shim minor stuff in the bulkhead, cabinet frames etc. I am mainly concerned about doors and hatch....
Second question: If I really do need to get rid of those 1/16ths, then suggestions about how to do that would be appreciated. The walls as now intended will overlap the sides--and that is the dryfit that I am having the problems with.
I could get rid of the problem by mounting the base of the walls (3/4") ON the floor but would like to have the walls overlap the sides if possible.
Curse the 1/16th's!
Jim
A disposition to preserve, and an ability to improve, taken together, would be my standard of a statesman...
But what is liberty without wisdom, and without virtue? It is the greatest of all possible evils; for it is folly, vice, and madness, without tuition or restraint.
Edmund Burke
kayakrguy
Images: 195
fit
Postby jay » Sat Aug 19, 2006 5:28 pm
the problem is the floor 5'0" and the walls. when set 90 degrees [plumb] are not parallel? so the width at the roof is 1/8" wider?
is the floor dead level? just like remodeling and boatbuilding, sometimes you need to toss out the bubble stick and make it right! and discrepancies need to be split, so you're 1/16" theory is on the right track. if each wall is 1/16" out of plumb [given a level floor] it's about 1/128" per foot of height which is only a pass or two with a block plane.
have you measured diagonals? they need to be equal if you're aiming at 90 degree intersections.
jay
Postby CHUCKLEHEAD69 » Sat Aug 19, 2006 6:03 pm
take it off the back side of the ply that mounts to the frame.1/16th of an inch would'nt take no time to get off whith a belt sander.just take your time and sand real careful.i would (personally) just cut the spars 5 foot and roll with it. :)
JUDE ------- "Laissez les bons temps rouler. let the good times roll"
CHUCKLEHEAD69
Images: 58
Postby Hamcan » Sat Aug 19, 2006 7:27 pm
Jeez I am almost speechless.
Each wall is out 1/16"...................well I will be slung down and stomped!
Work that sloppy should not be tolerated imho. Where are the Teardrop police, there has been a violation of the anal retentive laws.
Ok Ok I'm kidding. Jim I guess you are building a really nice project and for that I can't be much help since I just wanted to go camping in something that made sense to me [ie: something smaller than that produced by Gargantua Motors] so I built mine like it was a little house on little wheels and used a lotta trim!
Sorry, this is no help unless you like trim.
Just couldn't resist, JG
Hamcan
Images: 25
Postby mikeschn » Sat Aug 19, 2006 8:16 pm
I would measure the walls at the floor, and cut the spars to the same length.
You mention you are not quite perpendicular... Very few squares are true over a 4' length. So go with the numbers, and it should work out...
P.S. Do you know how to measure diagonals with your tape? Double check the squareness with diagonals...
Postby scopeaddict » Sat Aug 19, 2006 8:22 pm
mikeschn wrote:I would measure the walls at the floor, and cut the spars to the same length.
correct me if im wrong, i might of forgotten,
but isnt it 4ft one way,,,3ft the other way,,, and 5ft on the angle???
or 8-6-10,,
to be square?
johnp
Deep Sky imaging and need a warm place to curl up,
Have 4-angry squirrels powering a Jeep YJ,
will travel, eventualy,,grin
scopeaddict
Postby Dean in Eureka, CA » Sat Aug 19, 2006 8:24 pm
You can also use the 3-4-5 rule too...
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby mikeschn » Sat Aug 19, 2006 8:32 pm
Yes, the 3-4-5 rule is dead nuts accurate.
Postby madjack » Sat Aug 19, 2006 8:57 pm
mikeschn wrote:Yes, the 3-4-5 rule is dead nuts accurate.
...yep and physics, atmoshperic pressure or how you hold your mouth or the angle of your hat will have no effect...'course an inaccurate tape measure can drive ya nuts :D ;)
Postby mikeschn » Sat Aug 19, 2006 9:02 pm
A change in temp or humidity will change your numbers though... Be sure to make all your measurements within seconds of each other! :? :? :? :twisted: :twisted: :twisted: :R :R :R
Postby Miriam C. » Sat Aug 19, 2006 11:23 pm
:duh: Huh. What is a 3-4-5 rule? And please no dead nuts. :D
Aunti M
Postby madjack » Sat Aug 19, 2006 11:50 pm
...3-4-5 to find if a corner is at a perfect 90* angle, measure out one side 3', the other side out 4'...the straight line measurement between those two points will be 5'....3,4,5 inches will work as any thing that is a multipe, such as 6,8,10 or 12,16,20,
Postby Gerald_G » Sun Aug 20, 2006 2:15 am
Aunti M
Known as the The Pythagorean theorem, it is the ratio of a right angle triangle. ie: one corner is a perfect 90 degrees.
Since the formula is actually A(sqaured) + B(squared) = C(squared).
3 sqaured + 4 squared = 25, the square root of which is 5. (3-4-5)
There's a really good explanation on wikipedia.
http://en.wikipedia.org/wiki/Triangle
This is the kind of math really useful for daily activities such as building stuff.
Gerald_G
Images: 85
Postby kayakrguy » Sun Aug 20, 2006 7:02 am
Theory, theory, theory, that's what you get with a bunch of physicists! <g>
Edmund Burke
kayakrguy
Images: 195
Postby kayakrguy » Sun Aug 20, 2006 7:06 am
Wait! There was one non-physicist/ mathematician! Yes! Thanks, chuckle... As soon as I have done the Pythagorean thingie, Ill just fire up the sander! <g>
Jim
Edmund Burke
kayakrguy
Images: 195
