mikeschn wrote:I would measure the walls at the floor, and cut the spars to the same length.
You mention you are not quite perpendicular... Very few squares are true over a 4' length. So go with the numbers, and it should work out...
P.S. Do you know how to measure diagonals with your tape? Double check the squareness with diagonals...
mikeschn wrote:Yes, the 3-4-5 rule is dead nuts accurate.
Miriam C. wrote:mikeschn wrote:Yes, the 3-4-5 rule is dead nuts accurate.
Huh. What is a 3-4-5 rule? And please no dead nuts.
Aunti M
Users browsing this forum: Google [Bot] and 0 guests
