by asianflava » Fri Sep 01, 2006 1:07 am
You can if you want, I glued mine because it was easier to handle. I did nearly all the work by myself. It may delaminate but there are enough places on the body to hold it down if it does. So far mine is staying put.
In hindsight, I probably would have gotten away with just using 1/8in ply under the roof. I used 2 layers of 1/8in ply and staggered the joints to prevent leaks. Well, as Cedar Hill taught me, leaks come from everywhere. I only have 1 layer of 1/8in on the sides.
