Micro469 wrote:I want to make an outside frame for my slumbercoach but still unsure of how to do it. I want to make it 2" wide and use the longest pieces possible around the curves. I want the pieces joined at a pleasing angle rather than every piece a different angle. What size board should I get,3,6,8" wide and how do I plan the angles they join? I was thinking of picking a spot on the side of the trailer and the running a string to the edge, marking it and moving it to a spot farther down the curve. Is this right? I wish I knew cad, I could show you what I mean.....
There's no way you could call yourself a "carpenter" if you don't have a Sliding T-Bevel Square. Ain't got one? Get one.
Sears Sliding T-Bevel Square article wrote:There's no way you could call yourself a "carpenter" if you don't have a Sliding T-Bevel Square. Ain't got one? Get one.
Brick wrote:Well Steve... It all depends on what you are used to using? I've been a carpenter for a LONG time... and I seldom use a sliding T-bevel. Somehow, I seem to always get the job done.
sdtripper2 wrote:Brick:Sears Sliding T-Bevel Square article wrote:There's no way you could call yourself a "carpenter" if you don't have a Sliding T-Bevel Square. Ain't got one? Get one.Brick wrote:Well Steve... It all depends on what you are used to using? I've been a carpenter for a LONG time... and I seldom use a sliding T-bevel. Somehow, I seem to always get the job done.
That quote was from the Sears article I copied. I really didn't know about a
Sliding T-Bevel Square so it was of interest to me that they thought one
would have to have one to be a carpenter.
Brick I will defer to a real carpenter any time as to the use of this tool.
It seems it would be of value if you didn't want to strap boards all up to
make angles such as your picture above. However ... again maybe your
way is the fastest and best way for many carpenters.
It would seem to me that the use of a Sliding T-Bevel Square with the use
of this Bevel Boss straight edge angle finding tool would be a good combo?
Would like to get your opinion and Danny's about the use of these two tools
together?
Bevel Boss
http://www.sutherlandtool.com/bevelboss.html
