Podunkfla wrote:KDOG... ............. If you are going to do just a little more work; you can use 1/4" plywood, 3/4" wood framing and even go as thin as 1/8" for the inside skin... prolly for little more than the good plywood would cost. Plus, you have the extra added benefit of using 3/4" foam insulation in the walls AND you can hide all your wiring in the walls too. Needless to say, this is the most popular way of building them around here... and lots of pic of how it's done too.
toypusher wrote:Podunkfla wrote:KDOG... ............. If you are going to do just a little more work; you can use 1/4" plywood, 3/4" wood framing and even go as thin as 1/8" for the inside skin... prolly for little more than the good plywood would cost. Plus, you have the extra added benefit of using 3/4" foam insulation in the walls AND you can hide all your wiring in the walls too. Needless to say, this is the most popular way of building them around here... and lots of pic of how it's done too.
This is exactly what I would recommend!! Using this method you can even hide all the screws on the outside if you want a woody look.
