Wall thickness- 3/4" or will 1/2" work fine as wel
Postby KDOG » Tue Mar 27, 2007 11:39 pm
Looking at the generic Benroy plans, it has the walls at 3/4" birch. Wow. Those suckers will be HEAVY!. Won't 1/2" work just as good?
FAILURE TO PLAN ON YOUR PART DOES NOT CONSTITUTE AN EMERGENCY ON MY PART.
KDOG
Postby Miriam C. » Tue Mar 27, 2007 11:43 pm
8) Yep. If you frame it out you can go even smaller. ;)
Postby KDOG » Tue Mar 27, 2007 11:53 pm
Cool. I don't think I'll go less than 3/8ths" though.
KDOG
Postby Podunkfla » Wed Mar 28, 2007 4:12 am
KDOG... You could use 1/2" plywood for the sides. But, you really need to use "cabinet grade" plywood because the construction grade stuff you see in most of the big-box stores almost always isn't flat enough and has a real tendancy to warp unless it is nailed down to a frame. The cabinet grade stuff is kinda spendy, although very stable and flat. So... If you are going to do just a little more work; you can use 1/4" plywood, 3/4" wood framing and even go as thin as 1/8" for the inside skin... prolly for little more than the good plywood would cost. Plus, you have the extra added benefit of using 3/4" foam insulation in the walls AND you can hide all your wiring in the walls too. Needless to say, this is the most popular way of building them around here... and lots of pic of how it's done too.
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby toypusher » Wed Mar 28, 2007 6:09 am
Podunkfla wrote:KDOG... ............. If you are going to do just a little more work; you can use 1/4" plywood, 3/4" wood framing and even go as thin as 1/8" for the inside skin... prolly for little more than the good plywood would cost. Plus, you have the extra added benefit of using 3/4" foam insulation in the walls AND you can hide all your wiring in the walls too. Needless to say, this is the most popular way of building them around here... and lots of pic of how it's done too.
This is exactly what I would recommend!! Using this method you can even hide all the screws on the outside if you want a woody look.
toypusher
Images: 324
Postby Ira » Wed Mar 28, 2007 7:16 am
This is what I did too--but wasn't the ply "labeled" as 3/8"? Or it's labeled 1/4", but actually measures 3/8"? I forget what the Cubby plans call for, but I followed that.
Here we go again!
Ira
Forum Storyteller
Images: 118
Users browsing this forum: Google [Bot] and 3 guests
