Drawing Ellipses
Drawing Ellipses
Postby IndyTom » Thu Mar 29, 2007 7:57 pm
I am about to pull out the very little hair I have left. I am trying to get my walls ready to cut out and tried drawing my first elliptical arcs tonight. I was using screws at the loci, and some steel wire to make my loop. I could not get it to come out right.
Can anyone shed some light on this for me?
Never trust a skinny cook
IndyTom
Images: 42
Postby Miriam C. » Thu Mar 29, 2007 8:21 pm
Tom, Andrew has a how to on his website.
http://www.angib.pwp.blueyonder.co.uk/t ... tear80.htm
Enjoy
Postby bdosborn » Thu Mar 29, 2007 8:25 pm
Here you go:
clicky to Andrews Site
I used the info to make an ellipse on the rear of my trailer and it worked great.
Images: 806
Doh! 4 minutes too slow!
Images: 806
Postby Sonetpro » Thu Mar 29, 2007 8:37 pm
Tom,
When I did mine I bought these little pulleys from the hardware store. I ground the pin off and had 2 nice roller bearings. I just screwed the wheel to the loci and used 12 ga stranded wire it was more flexible than the steel wire. It rode in the wheel concaves perfectly and made a smooth elipse.
Sonetpro
Images: 107
Re: Drawing Ellipses
Postby bdosborn » Thu Mar 29, 2007 9:58 pm
IndyTom wrote:I am about to pull out the very little hair I have left. I am trying to get my walls ready to cut out and tried drawing my first elliptical arcs tonight. I was using screws at the loci, and some steel wire to make my loop. I could not get it to come out right.
I just used a piece of string instead of wire. It took me awhile to get the ellipse in the right spot but drawing wasn't a problem.
Images: 806
Postby Dean in Eureka, CA » Fri Mar 30, 2007 2:10 am
Tom,
Definately use Andrew's guide and be sure you are doing your calcs correct to get the loci points and have them on the correct axis. (Major I think)
A piece of plumb bob string worked fine for me, although keeping the correct tension on the string line when swinging the big rear elipse was a bit dicey.
After you get your arcs drawn, it might be a good idea to check them and fair them, if neccesay, with a batten and some small brads.
Cut out just proud of the line with a jig saw and belt sand them into shape, but use care that the edge is at a 90 degree angle to the surface when using the belt sander. I made a hand sanding jig to do fine touch ups here and there after using the belt sander...
BTW- That was for the template.... Once I had that, I used it as a router guide and a router to to trim my walls into shape.
We wanna see pics by the weekend. ;)
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby angib » Fri Mar 30, 2007 9:23 am
Yup, biggest problem with drawing ellipses is stretchy string. Using metal wire seems an extreme reaction, but then I've never tried it.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby IndyTom » Fri Mar 30, 2007 9:37 am
OK, I feel sheepish. I knew I had seen a tutorial on drawing ellipses but had completely forgotten that it was on Andrew's site. And to think, it was discovering Andrew's site by accident that started this insanity.
Sonnet Pro, I new I had seen some sort of roller, so thank you for reminding me.
Andrew, The steel wire was left over from the electified fence I had to put up to contain my overly enthusiastic beagle, and was what I had handy in the garage.
I will pick up a couple of the pullies and some stranded wire later today.
IndyTom
Images: 42
Postby Mark72 » Fri Mar 30, 2007 8:08 pm
Tom, your not the only one that was sucked in by Andrew's wonderful website! It sure takes all the hard figuring out of it! Thanks Andrew!
Mark :thumbsup:
P.S. I used twine to draw my eliptical arc, It dosn't have the strechy properties that nylon string has.
Mark72
Images: 127
Postby IndyTom » Sat Mar 31, 2007 8:13 am
[quote="Mark72"]Tom, your not the only one that was sucked in by Andrew's wonderful website! It sure takes all the hard figuring out of it! Thanks Andrew!
Mark :thumbsup:
The strange thing about it Mark, is that I was looking for sailboat plans when I came across Andrew's site. Building a camper was something that I had never thought of.
IndyTom
Images: 42
