Are the walls heavier with solid wood as apposed to sandwiched insulated walls, or vise a versa? Or does it really matter?
Thanks
Bill
Podunkfla wrote:3/4" plywood is quite a bit heavier than most insulated walls...
If you use 1/4" outside, simple 3/4" pine framing and 1/8" inside
like a lot of folks have... It prolly weighs a bit over half as much.
It may be more work, but I think insulating the walls is the way to go.
Just my .02 worth.
kennyrayandersen wrote:I'm new and haven't posted much becasue I'm just learning, but I am an aerospace engineer .
