Curious but had to ask - Fiberglass Exterior Roof
Postby Classic Finn » Sun Jul 01, 2007 8:22 am
Those of you that have skinned your tear with the White Fiberglass - (On the Roof - Exterior.. how thick of ply did you use underneath?
I was thinking of 3mm since my Fiberglass Sheeting is 1.8 mm in thickness but actually does it need to be at that thickness? I do have the 1.5 mm ply sheeting left...
Maybe Paul from Down Under can chime in... :thinking:
Classic Finn ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Classic Finn » Sun Jul 01, 2007 12:54 pm
Now there has to be some fiberglass tears out there... :thinking: :thinking:
Classic Finn
Classic Finn
Images: 146
Postby glassice » Sun Jul 01, 2007 1:11 pm
can you use hi dent foam underneath. that way you have more insulation for the weight
It is not the return ON my investment that I am concerned about; it is the return OF my investment
glassice
Postby Classic Finn » Sun Jul 01, 2007 1:51 pm
glassice wrote:can you use hi dent foam underneath. that way you have more insulation for the weight
Good evening Glassice... Its a pleasure to hear from you..
Can you tell me what you mean by high dent foam please? I have 50mm
foam on the ceiling at present..is that enough?
I just thought it would be sort of a waste to put another layer of ply underneath unless its for strength purposes :thinking: :thinking:
Best regards to You.
Classic Finn and Family ;)
Classic Finn
Images: 146
Postby glassice » Sun Jul 01, 2007 2:05 pm
I use the brown ins 1 " on are trailers the glass is to stop you from putting your finger through the foam If you can glue the 2 together it supper strong like some jet fighters are made that way .I see you did a great job fixing your fender :thumbsup: when we do the round parts cut in to 2" strips lay in and fell in with 2 part foam( it's cheep that way) can foam will work but not as strong
glassice
Postby Classic Finn » Sun Jul 01, 2007 2:14 pm
glassice wrote:I use the brown ins 1 " on are trailers the glass is to stop you from putting your finger through the foam If you can glue the 2 together it supper strong like some jet fighters are made that way .I see you did a great job fixing your fender :thumbsup: when we do the round parts cut in to 2" strips lay in and fell in with 2 part foam( it's cheep that way)
Ok now I understand what you mean...gotcha..glue some foam on the underneath for extra strength.. :thumbsup: :thumbsup:
I did do some repair on the fender a few days ago.. its looking better than it did.. 1st time playing with small amounts of fiberglass ever.. :lol: :lol:
Thank You Glassice
Classic Finn ;)
Classic Finn
Images: 146
Postby glassice » Sun Jul 01, 2007 2:22 pm
now you should get a pay raise when you are flying and get a hold in the wing you can run out and fix it with out landing :D
glassice
Postby Classic Finn » Sun Jul 01, 2007 2:31 pm
glassice wrote:now you should get a pay raise when you are flying and get a hold in the wing you can run out and fix it with out landing :D
Ahh shucks.. :oops: :oops: Thank You Glassice.. :thumbsup:
Classic Finn ;)
Classic Finn
Images: 146
