Under floor paint, this OK?
Postby Steve F » Sun Aug 19, 2007 6:20 am
Looking at using this for painting the underside of my floor http://www.crommelin.com.au/images/newProducts/Exterior%20Grade%20Brushable%20Waterproofer.pdf
Anyone see any problems with it? I can get it locally but am not sure on the price yet which may make all the difference.
Cheers
Steve F
Images: 25
Postby kirkman » Sun Aug 19, 2007 7:43 am
Looks good to me I bet it is expensive though! ...Looks like you could even use it to paint the outside of your tear with also.
kirkman
Images: 55
Postby Podunkfla » Sun Aug 19, 2007 7:53 am
Looks like high tech stuff. I imagine it would do fine. From what I read it seems like a similar product to elastomeric roof coatings I have used before. Good stuff, but expensive.
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby Arne » Sun Aug 19, 2007 8:07 am
wonder if it flows and lays flat when cured, or if it has a texture to it?
Anyone have any experience with it..?
I used roofing tar on the bottom and am still thinking about cpes, primer and a good quality house paint on the tear.
Oh, I have to add that I think brightside gives about the best, non-porous surface, but is a bit brittle.... I do think white house paint, no matter how high quality, would be porous and get dirty after a while.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Lazybones » Sun Aug 19, 2007 12:44 pm
Just use a good oil based primer and paint. I did and the bottom of my trailer looks great after seven years.
Is it true? Is it necessary? Is it kind? Ask yourself these simple questions every time you are in doubt about any action.
Lazybones
Images: 49
Postby nikwax » Mon Aug 20, 2007 9:37 am
I just did oil based primer and spar enamel. About $30 for all three coats. If it's good enough for boats, it should be good enough for me :)
nikwax
Images: 30
Postby Miriam C. » Mon Aug 20, 2007 1:08 pm
I used fibered roof coating but this look good. No reason you can't use it. :thumbsup:
Postby madjack » Mon Aug 20, 2007 1:14 pm
...we sprayed 4 coats of thinned(10-15%) outdoor rated polyurethane...any product that will permanently(more or less) seal the bottom of the floor is good enough...beware of using a belly pan(sheet metal/fiberglass/plastic), as they can cause moisture to be held against the floor, inducing rot.........
Postby Steve F » Mon Aug 20, 2007 9:35 pm
I ended up just painting with a good quality outdoor paint, the climate here in Sydney is pretty mild and we've been in a drought for close on 6 years now so water isn't too much of a problem in that regard :( Apart from that the trailer will be garaged when not in use.
The product I posted looked good price wise until I looked at the coverage 1 lt per 1 sqm so I'd need about $60 of the stuff to paint the underside of the floor.
Cheers
Steve F
Images: 25
Postby Micro469 » Mon Aug 20, 2007 9:39 pm
I gave the underside about 5 coats of CPES, nad then painted it with grey rusoleum...Hope it lasts...... :roll:
John
Micro469
Images: 382
