How thick are your galley doors?
Postby benzu » Mon Aug 20, 2007 3:53 pm
How thick are the ribbs of your galley, mine currently are drawn up to be 2'' and I'm not sure if that is enough or should I go bigger. My problem is if I go bigger then I lose out on galley space.
Mike
benzu
Images: 119
Postby Miriam C. » Mon Aug 20, 2007 4:21 pm
Mine are 2" (sort of) there are some jiggy places where they are bigger or smaller. :D
Can't imagine them bigger.. :thumbsup:
Postby madjack » Mon Aug 20, 2007 4:59 pm
2"s should be adequate...I reccomend then in the horizontal as opposed to vertical...helps alleviate the dreaded springback...
Postby rbeemer » Mon Aug 20, 2007 5:16 pm
MJ,
don't you have that backwards????
You want to run them vertical(top to Bottom) not horizontal(Side to side)
Though I should of asked first what are you using for your ribs?
I would not suggest using barbeques sauce though :lol: :lol:
Rick
If ducks had scales, would fish quack?
rbeemer
Postby Gerdo » Mon Aug 20, 2007 8:24 pm
I presume you are talking about your hatch. I have two main ribs, one on each side, that is almost 4" wide. Then I have spars going from side to side that are 1x2s
Gerdo
Images: 156
Postby Roly Nelson » Mon Aug 20, 2007 9:13 pm
Hi Mike, I have built 2 tears, one with laminated 2", 3/4 pine, bandsawed vertical members, which are plenty solid and no springback at all. The other is super-lightweight, just 1/2 inch baltic birch plywood, bandsawn, 1 1/4 at top and bottom, but thicker in the middle. If I were to build again, I would double the 1/2 inch baltic birch, I think it looks nice and is super strong.
Roly......I believe vertical members will result in less (if no) springback :thinking:
Roly Nelson
L'il Ol' Woody Builder
Postby benzu » Mon Aug 20, 2007 9:40 pm
Thank you for that info, I'm going to stick with 2'' it works with our layout.
Mike :D
benzu
Images: 119
Postby madjack » Mon Aug 20, 2007 9:51 pm
rbeemer wrote:MJ,
oppppsssssss :oops: ...your right, I guess I was havin' a dyslexic moment........................ 8)
Postby Micro469 » Mon Aug 20, 2007 10:03 pm
madjack wrote:
rbeemer wrote:MJ,
You got your computer lying sideways again...... don't you....... :R
John
Micro469
Images: 382
