How thick are the ribbs of your galley, mine currently are drawn up to be 2'' and I'm not sure if that is enough or should I go bigger. My problem is if I go bigger then I lose out on galley space.
Mike
rbeemer wrote:MJ,
don't you have that backwards????
You want to run them vertical(top to Bottom) not horizontal(Side to side)
Though I should of asked first what are you using for your ribs?
I would not suggest using barbeques sauce though![]()
madjack wrote:rbeemer wrote:MJ,
oppppsssssss...your right, I guess I was havin' a dyslexic moment........................
