JunkMan wrote:I was thinking about making the pattern for the sides of my tear. Most of the things I have made in the past did not require a pattern, so I'm trying to figure out the best way to make one.
What if I made the pattern out of 3/4 particle board, then attached legs to the bottom, so I could also use it as my workbench. It would be the right shape to clamp everything down, and wouldn't move around when I was working on it. When looking at pictures of other peoples construction, it seems like clamping things (framing) down it might be a problem, when the work bench is rectangular, and the part you are building is sort of an oval (unless I screwed clamps to the bench like Steve does).
The question is, would it work as a work table and a pattern, or should the pattern be something seperate that I can flip over and move around (Could I make both sides with just one side of the pattern facing up)?
Sounds like I have a disciple!!
If you're going to make a bench, I'd suggest a regular old bench. I've used a pair of horses with a couple of moveable tops.
And, I'm currently using a dedicated bench, built to support the wall panels perfectly flat and square.
The benefit is, the ability to use the bench to layout, cut, assemble wall panels, even assemble the body, on a flat, square surface. And, I can "clamp" my work anywhere with screws.
My method of construction relies on the use of the pattern throughout the build process. I take the pattern, and cut it to the requirements of the next step, and use it over-and-over, 'til it's used up! Each step "should" match up to the other steps, since they are all cut from the same reference points. I'll use that pattern to cut out doors, lay out the wall framing, cut panels, interior and outside. The pattern was used as a jig to fabricate the wall framing. I got this idea from Asian Flava. I just lay the frame out on the jig, to the layout lines, glue it together, and remove to make the next side. I did the frames for both 'Diners this way. Lay waxed paper under the frame unless you want it glued to the pattern!:oops:
I used the pattern, modified, to cut a ledge for the headliner to rest on, rather that install the ceiling from inside the cabin, I just lay it on that ledge!
To cut both sides at once, just place the two side panels, good sides,or exterior sides, together. Lay your pattern on top, clamp the stack together and cut out with a top-bearing pattern bit in your router. Make sure there are no voids or dips in the pattern, as these will show up in the finished panels. You can add the aluminum for the sides to the stack and cut everything at once. Just go slowly and use a good, carbide bit.
Since I'm building two copies of the Lil'Diner, the pattern has been well used!
I'll shut up now!!:MLAS
