TRAIL-OF-TEARS wrote:I used a paper pattern I made using My cad program then printed it full size. It took 6 36x46 sheets.
JunkMan wrote:I was thinking about making the pattern for the sides of my tear. Most of the things I have made in the past did not require a pattern, so I'm trying to figure out the best way to make one.
What if I made the pattern out of 3/4 particle board, then attached legs to the bottom, so I could also use it as my workbench. It would be the right shape to clamp everything down, and wouldn't move around when I was working on it. When looking at pictures of other peoples construction, it seems like clamping things (framing) down it might be a problem, when the work bench is rectangular, and the part you are building is sort of an oval (unless I screwed clamps to the bench like Steve does).
The question is, would it work as a work table and a pattern, or should the pattern be something seperate that I can flip over and move around (Could I make both sides with just one side of the pattern facing up)?
asianflava wrote:WOW! I got props from one of the seasoned builders!![]()
asianflava wrote:How big is your shop? I had to do all my work on the floor because I couldn't dedicate that much room for a table. I did a lot of crawling on my hands and knees. I ended up getting kneepads for my knees but my hands hurt after awhile.
mikeschn wrote: (Yes I am going to plug the holes and paint it with epoxy paint again!)
Ken A Hood wrote: The current profile I'm going with is approx. for a 5' x 11-12'.
