Minimum dimensions of a Loo
Postby fornesto » Fri Nov 09, 2007 1:12 pm
What are the absolute smallest dimensions for a "loo" closet? Terlet only - no sink or shower.
fornesto
how wide?????
Postby Steve Nikkel » Fri Nov 09, 2007 1:29 pm
minimum space is easy--------are you wider at the shoulders or is it down lower? measure widest dimension, set two pieces of cardboard upright on either side at that space. Now sit on something loo height while between them-----how much farther do you need to spread them to reach around and under to wipe yer bum? You now have found minimum dimension. :oops: :oops:
Steve Nikkel
I'm Draggin-----Draggin the Main once more
With a Peroxide Blonde in a hopped up model Ford.
(Brian Setzer)
Steve Nikkel
Postby fornesto » Fri Nov 09, 2007 1:59 pm
24" width is perfect. The depth should probably be 36". At some point, you've got to abandon the idea of a compartmentalized loo in a small trailer and just figure that nobody's gonna be really executing too much business with a full house. I'll keep workin'.
fornesto
Postby mikeschn » Fri Nov 09, 2007 4:50 pm
In my Fun Finder the bathroom was 21" wide, and I could not use it unless the door was open.
I don't know what the minimum width ought to be, but if you are right handed you could push the loo all the way to the left, and if you allow about 8" for your right elbow, I think you'd be okay. I think the magic number is somewhere between 24 and 32 inches, and probably closer to 32.
Postby angib » Fri Nov 09, 2007 7:12 pm
Yep, I'd second 36" x 24" as the minimum practical size.
As this space is used so little the rest of the time, it's worth cutting the permanent space down to that require to house the toilet itself, and then making the 'leg/foot space' in front of it temporary. Here's one way of doing this with a bi-fold door:
Frankly a curtain is pretty nearly as good.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Miriam C. » Sat Nov 10, 2007 12:15 am
:thumbsup: A curtain in a U shaped bow would give a lot of room and could still be tucked out of the way. :thumbsup:
Postby Gage » Sat Nov 10, 2007 12:30 am
Just be sure to lock the door that opens to the outside world. :lol:
Image Image Image
Gage
Images: 28
Postby madjack » Sat Nov 10, 2007 1:23 am
Gage wrote:Just be sure to lock the door that opens to the outside world. :lol:
...suh-prize, suh-prize, suh-prize... :lol: :lol: :lol: ................................................. 8)
Postby angib » Sat Nov 10, 2007 7:04 am
As I just copied this design from a boat my dad had when I was a boy, I can tell you that being able to open the outside door while still, errr, 'sitting down', can be a big benefit......
'Odour control', if you have to ask. :oops:
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby GPW » Sun Nov 11, 2007 6:55 am
For minimum size just stick both elbows out, measure, that's the size , and good for a shower too... mine's 34". but I'm Large... @6'3'' , 230LBS...:o FITS EVERYBODY ELSE TOO... ;)
Postby jeepr » Sun Nov 11, 2007 10:27 am
angib wrote:Image
If you ever look inside of a camper van they do the same kind of thing. The door to the loo opens and becomes the door between the loo and the rest of the van.
Roadtrek is the manufacturer I was thinking of. I haven't been able to find a pic of the bathroom though.
Mike C.
jeepr
Images: 38
Postby Boodro » Mon Nov 12, 2007 3:11 pm
Here's a Loo for ya! :lol: :lol: :lol:
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Postby Gerdo » Mon Nov 12, 2007 6:22 pm
Mine is just a little wider than our shoulders. It is for my wife, mainly at night. It is in the front of our TD and we sleep with out heads away from it. It is on my wifes side so she doesn't wake me. Notice the door is above the matress. She uses it with the door open, I just don't look.
Gerdo
Images: 156
Postby mikeschn » Tue Nov 13, 2007 5:18 am
Gerdo,
That's a real good way to add a Loo to a typical teardrop. ;)
Postby bobhenry » Tue Nov 13, 2007 8:42 am
fornesto wrote:24" width is perfect. .
I wear 4XL shirts and I say 24" is perfect for WHAT
At 30" wide I would have to find someone to do the paperwork for me.
